Edit a User_comp .c file and utilize
04 May 2022 16:43 #242010 by chak257
Edit a User_comp .c file and utilize was created by chak257
So I have a GS20 vfd. It is the replacement for the old GS2 drive that the existing hal component exists for. I am only using it to pull vfd status, load %, current, voltage, and generate some user messages. I am using the 0-10v and fwd/rev start/stop physical pins from my mesa 7176e card.  I plan on adding an encoder for rigid tapping down the road so I want realtime spindle control rather than modbus.  All I want from modbus is some status messages and the ability to send a reset command.   I found the gs2_vfd.c file on the github repo, and I can verify that the modbus hex register locations have changed for the gs20 for some items and I would like to re-write this file for the gs20.
I have no problem editing the .c file, but my question is how do I utilize this file afterwords? Do I need to install the dev version of linuxcnc to have access to source files?
04 May 2022 17:03 #242012 by andypugh
Replied by andypugh on topic Edit a User_comp .c file and utilize
halcompile might work, you might as well try it.
halcompile --install ....c
If that says you don't have halcompile, then install linuxcnc-dev (or linuxcnc-uspace-dev ) and try again.
Time to create page: 0.370 seconds
