Wireless MPG XHC-HB04 prob when going from 2.7 to 2.8
- dannym
06 May 2022 14:14 #242164
by dannym
Wireless MPG XHC-HB04 prob when going from 2.7 to 2.8 was created by dannym
I'm building a new box with LinuxCNC 2.8.2 now.
It's working, except the XHC-HB04 will not work prior to homing the machine. No response. This may be intentional, but undesirable. We often use it to set up the machine prior to homing. You can use the keyboard, sure.
This is a makerspace with a broad user base and we don't communicate changes easily to the whole community. While this limitation would probably not bother me alone, I can foresee questions from users lingering for months on minor things like this.
Why does it not work now prior to homing, and can it be reenabled?
Also I do have a "RESET DRIVES" button on the screen to pull the hardware reset pin which briefly depowers the motors that also unhomes the axes in software, since they were depowered and the position is not certain. It now gives an error that it can't dehome and something about "joint mode", and won't dehome. What's this about and can I make it work?
- Thank you received: 4656
06 May 2022 14:57 #242169
Replied by andypugh on topic Wireless MPG XHC-HB04 prob when going from 2.7 to 2.8
You need to connect the jog-counts and jog-enable to _both_ the axis and the joint jog pins.
The conversion script is meant to do that for you. I am disappointed if it didn't.
- dannym
07 May 2022 00:13 #242204
by dannym
Replied by dannym on topic Wireless MPG XHC-HB04 prob when going from 2.7 to 2.8
Hmm, here's my xhc hal file, any advice?
07 May 2022 15:44 - 07 May 2022 15:45 #242250
It looks like you caught most of it already, but missed:
should be
# Jog wheel and axis selection button
net jog-x axis.x.jog-enable <= xhc-hb04.jog.enable-x
net jog-y axis.y.jog-enable <= xhc-hb04.jog.enable-y
net jog-z axis.z.jog-enable <= xhc-hb04.jog.enable-z
net jog-a axis.a.jog-enable <= xhc-hb04.jog.enable-ashould be
net jog-x axis.x.jog-enable joint.0.jog-enable <= xhc-hb04.jog.enable-x
etc
Last edit: 07 May 2022 15:45 by andypugh.
Time to create page: 0.101 seconds
