Jogwheel + start of any gcode motion causes Following Error
- Thank you received: 2181
30 May 2022 20:18 #244252
Replied by cmorley on topic Jogwheel + start of any gcode motion causes Following Error
Ok. I did some basic testing with qtaxis and didn't see any obvious problems.
The user had some other problems fixed so maybe it was unrelated to this work.
- dannym
31 May 2022 13:55 #244305
by dannym
Replied by dannym on topic Jogwheel + start of any gcode motion causes Following Error
I think "the user" is me, right?
No other probs other than I think not being able to move coordinated joints in Joint mode, prior to homing, is a significant problem. An unrelated issue.
This Following Error is the only unexplained prob I have now that is keeping me from upgrading our makerspace CNC router to 2.8.
02 Jun 2022 05:08 #244436
I think that you should be able to install the 2.8 deb from the buildbot, then reset the repository settinngs to the main server. That should bring in the f-error fix and then prompt to install the next 2.8 release (with the fix) when that is released.
Replied by andypugh on topic Jogwheel + start of any gcode motion causes Following Error
- dannym
02 Jun 2022 20:43 #244482
by dannym
Great- can you explain it like I'm 5?
I'm not familiar with buildbot or repository settings
Looking forward to this fix
05 Jun 2022 08:17 #244613
There are instructions here.
buildbot.linuxcnc.org/
Follow then”alternative” route to installing the keys.
05 Jun 2022 08:17 #244614
- dannym
14 Jun 2022 00:46 #245099
by dannym
I have installed it, and it is magic
Thank you!
Thank you!
- dannym
01 Jul 2022 00:53 #246341
by dannym
I just got this strange error when I handed the mpg to a student and had them press "Probe Z". Never saw this with 2.6 I couldn't repeat it. He swears he didn't move the jogwheel while pressing Probe Z."Probe tripped during a coordinate jog""joint jog requested for undefined joint number = -1 (max=0, min=4)"??
01 Jul 2022 04:29 #246348
That is weird, because I don't know of any way to select a joint to jog by number. (each joint has a pin to select it for jogging, and you can't select a joint that doesn't exist)
It's possible that the probe trip is the only real issue, and the rest is a result of an aborted jog.
Time to create page: 0.103 seconds
