limit3 component question
03 Jun 2022 05:29 #244496 by robertspark
limit3 component question was created by robertspark
Anyone using / used the limit3 component receintly?
Application: router speed ramping
LinuxCNC 2.8.2-11.g6a3d0a434
Issue: basically I can't seem to get an output from the component output pin
I have tried changing limit3.load from FALSE to TRUE... no change in output.
I can confirm that I have an input (tried 5000, 10000 and 30000), and no change on the output.
Yes I am probably being a muppet and not seeing the obvious.... pointing out the error of my ways would be most helpful, thanks.
Oh, using Hal Meter to inspect the I/O's state
just trying to smooth out my spindle (router) speed change, as it had soft start and is now running with a Super-PID
#SINDLE RAMP CONTROL
loadrt limit3 names=spindleramp
# settings
setp spindleramp.maxv 2
setp spindleramp.maxa 10
setp spindleramp.max [SPINDLE_0]OUTPUT_MAX_LIMIT
setp spindleramp.min [SPINDLE_0]OUTPUT_MIN_LIMIT
setp spindleramp.load 1
# input & output
net spindle-vel-cmd-rpm-abs => spindleramp.in
net spindleramped <= spindleramp.out
[SPINDLE_0]OUTPUT_MAX_LIMIT = 30000
[SPINDLE_0]OUTPUT_MIN_LIMIT = 5000
I'm going to give limit2 a shot in the meantime.... maybe the error of my ways will become apparent
Note:  I have flipped LOAD from False to True and no change on output (I thought this was a pass through function)
Minor thing....
Noticed the documentation (2.8 / stable or master) did not list the pin
limit3.time FLOAT OUT
linuxcnc.org/docs/stable/html/man/man9/limit3.9.html
03 Jun 2022 05:45 #244498 by phillc54
Replied by phillc54 on topic limit3 component question
I don't see an addf to a thread.
The following user(s) said Thank You: robertspark
03 Jun 2022 05:55 #244503 by robertspark
Replied by robertspark on topic limit3 component question
..... head slap moment !!!!
I figured that out after trying limit 2 and limit1......
addf spindleramp servo-thread
hey ho....
03 Jun 2022 06:01 - 03 Jun 2022 06:22 #244506 by robertspark
Maybe the below will help someone out in the future.....
choose ONE ( limit3 , limit2 or limit1 ) and modify to your needs
#SPINDLE RAMP CONTROL LIMIT 3
# settings
setp spindleramp.maxv 6000
setp spindleramp.maxa 6000
#setp spindleramp.load 1
setp spindleramp.enable 1
# input & output
#SPINDLE RAMP CONTROL LIMIT 2
#loadrt limit2 names=spindleramp
#addf spindleramp          servo-thread
# settings
#setp spindleramp.maxv 1000
#setp spindleramp.max [SPINDLE_0]OUTPUT_MAX_LIMIT
#setp spindleramp.min [SPINDLE_0]OUTPUT_MIN_LIMIT
#setp spindleramp.load 0
# input & output
#net spindle-vel-cmd-rpm-abs => spindleramp.in
#net spindleramped <= spindleramp.out
#SPINDLE RAMP CONTROL LIMIT 1
#loadrt limit1 names=spindleramp
# settings
# input & output
Last edit: 03 Jun 2022 06:22 by robertspark.
03 Jun 2022 06:11 #244508 by phillc54
Haha, I have those all the time.
03 Jun 2022 09:05 #244521 by robertspark
bit of an adjustment to the above / earlier posted code.
Added the mux2 component to act as a signal switch which prevents the minimum output of the limit3 component being sent to the PWM signal output pin.
loadrt mux2   names=spindlesw
addf spindlesw            servo-thread
# settings
setp spindlesw.in0 0
# input & output
net spindle-vel-cmd-rpm-abs-sw <= spindleramp.out
net spindle-cw => spindlesw.sel
net spindle-vel-cmd-rpm-abs-sw => spindlesw.in1
net spindleramped <= spindlesw.out
Time to create page: 0.159 seconds
