vfdmod issue connecting Yaskawa GA500
- ddB0515
- Thank you received: 7
25 Jun 2022 10:33 #245863
by ddB0515
vfdmod issue connecting Yaskawa GA500 was created by ddB0515
Hello all
I'm trying to connect my Yaskawa GA500 to LinuxCNC 2.8.2 via RS485/Modbus but having issue to understand modbus configuration
As vfdmod support reading 03 and writing 10 should work with GA500
Here is TechnicalManual
On page 206 Start Modbus Communications (I have setup manually b1-01/b1-02 and b1-15/b1-16 to value 2 (modbus) )
And also followed guide to setup rest Modbus communications parameters H5-01 to H5-12.
Now trying to setup vfdmod but having issue with reading Modbus setup from technical manual (page 218)
I have issue with getting WRITE only to work as I can read with 03 very easy based on monitor table(page 219/220)
If anybody have experience or know how to understand this a bit better would marvellous
Also maybe is not possible to work with vfdmod so maybe I'm trying in vain
[Control]
FunctionCode=10 // using code to to write register
Address=0x???? // address
RunForwardValue=0x???? // fw
RunReverseValue=0x???? // rw
FaultResetValue=0x???? // fault
StopValue=0x0000 // stopIf anybody have experience or know how to understand this a bit better would marvellous
- ddB0515
27 Jun 2022 18:10 - 27 Jun 2022 18:18 #246031
by ddB0515
Replied by ddB0515 on topic vfdmod issue connecting Yaskawa GA500
Update:
I managed to get ModBus working for spindle with following settings
Now spindle starts but making weird noise and after some time start ramp up (by itself and off) then I get error, resetting it works but still trying to figure it what is wrong now
This is my common block
and frequency
Maybe I need to change A1-02 section but if default is V/f and not working not sure if is safe to change to any other and keeping spindle alive
Anyone know what this should be set to?
[Control]
FunctionCode=10 // write
Address=0x0001 // page 218 is crucial table with registers
RunForwardValue=0x0001 // depends how section H5-12 is set
RunReverseValue=0x0003 // can be opposite on selection in H5-12
FaultResetValue=0x0008 // stop bit
StopValue=0x0000Now spindle starts but making weird noise and after some time start ramp up (by itself and off) then I get error, resetting it works but still trying to figure it what is wrong now
[Common]
MaxSpeedRPM=24000
MinSpeedRPM=3000and frequency
[SpindleRpmIn]
FunctionCode=10
Address=0x0002
Multiplier=1
Divider=6Maybe I need to change A1-02 section but if default is V/f and not working not sure if is safe to change to any other and keeping spindle alive
Last edit: 27 Jun 2022 18:18 by ddB0515.
29 Jun 2022 15:46 #246207
Replied by andypugh on topic vfdmod issue connecting Yaskawa GA500
I would try mode 2, for a start. Or try altering the V/f parameters (which will be adjustable somewhere)
- ddB0515
30 Jun 2022 17:19 #246321
by ddB0515
Hello
Thanks for suggestion, I have tried it and not a lot changes, still whining(all modes)...but I managed to connect to Windows machine and read all parameters out
Check attached pdf (values with [M] are only changed values)
Also from my config currently if I start LinuxCNC I get "F50.00" shown on screen for minimum speed (3000)
And my calculation is (3000 * 5 / 3) = 5000 (as is setup frequency in 0.01Hz)
That also works if I setup max speed as min I get 400Hz on VFD screen(so calculation should work)
So that part I thing works fine, now I when I try to increase speed on +/- from UI my frequency is not changing at all on CFD but spindle starts to speedup/rumping up until halted and stopped
Also attached my HAL's maybe will tell more about issue
P.S
Still WIP so not final and some nets are not connected
P.S
- ddB0515
01 Jul 2022 17:20 #246398
by ddB0515
Managed to get it working with only changed parameters on Spindle
Got response from manufacturer Jianken regarding JGL80/2.2-R24 spindle
It was frequency issue and motor poles that were needed to be changed
This is response I got from Janken for parameters
If anyone else will need it, but got it now working without any noise/whining
Attached pdf with WORKING parameters via Modbus/RS485 (whole configuration will post after I finish whole project)
Basic parameters VFD requires to match the spindle
1). 220V AC
2) max current: 6.0A
3) input: three phase
4)asynchornous motor
5) max frequency: 400HZ
6) rated frequency: 400HZ
7) base frequency: 400HZ
8) 2-pole
9) time of speeding up & speeding down: It's better around 10~20 seconds (if the spindle goes to high speed too fast, or stops to zero speed too fast, the bearings tend to slip and then may break down)If anyone else will need it, but got it now working without any noise/whining
Time to create page: 0.248 seconds
