How to adapt the extended IO?
- chen1234
19 Jul 2022 03:15 #247752
by chen1234
How to adapt the extended IO? was created by chen1234
hi guys,
i have a raspberry pi but it doesn't have enough pins,
i have an IO expansion module, i can control the expanded IO,
but i don't know how to give this expanded IO to my axis (x, y,z...),
where should I look at this section?
please,chen
I want to give the extended IO to my axis like this:[/code]
please,chen
[code]net home-x joint.0.home-sw-in <= parport.0.pin-11-inPlease Log in or Create an account to join the conversation.
21 Jul 2022 13:32 #247978
Replied by andypugh on topic How to adapt the extended IO?
What sort of expansion module? I2C? SPI? something else?
You might need to write a HAL driver.
- chen1234
21 Jul 2022 21:50 #248001
by chen1234
Replied by chen1234 on topic How to adapt the extended IO?
thanks,and
My expansion device is IIC expansion (PCF8574), so how do I configure this hal driver and where can I see this?
22 Jul 2022 03:13 #248014
Do you need this IO to be realtime?
There are tutorials on the web about enabling I2C on the Pi (for example learn.adafruit.com/adafruits-raspberry-p...etup/configuring-i2c )
For non-realtime access you can use the built-in drivers. I think that for realtime use you would need to mmap the device. I suggest looking at the i2C kernel driver tutorials out there (but don't follow them) and look at the hal_pi_gpio LinuxCNC driver and try to combine the two.
You can probably write this driver using halcompile.
The following user(s) said Thank You: chen1234
- chen1234
22 Jul 2022 05:10 #248017
by chen1234
thanks andy,
I configured the Raspberry Pi to enable I2C,
I used python-smbus to test this expansion device, and I can control the high and low levels of this IO pin very well.
However, I don't know how to configure this io to my hal, thank you for your reply, I'll go and try to write this driver.
hope it won't be difficult .
22 Jul 2022 05:39 #248019
If you can find a way to read / write to the board using inb() and outb() then it is easy to write the HAL driver. (That is how the paralell port driver on x86 works)
hal_pi_gpio wrks somewhat similarly, except that it uses mmap to allow it to read the port data from (virtual?) memory locations:
github.com/LinuxCNC/linuxcnc/blob/master...rivers/hal_pi_gpio.c
I think that googling for Pi I2C and mmap might get you the required info.
It might well be as easy as changing the /dev/gpiomem here:
github.com/LinuxCNC/linuxcnc/blob/master...s/hal_pi_gpio.c#L164
to /dev/i2c-1 (or i2c-0)
raspberry-projects.com/pi/programming-in...ng-the-i2c-interface
I think that I would suggest starting with a _very_ simple HAL component written with halcompile that first of all reads the data into a single u32 HAL pin using the sample code above, then look at memory-mapping that port, and only then worry about setting individual bit-type HAL pins and configuring port directions.
- cakeslob
- Thank you received: 280
09 Aug 2022 18:30 - 09 Aug 2022 18:33 #249435
by cakeslob
Replied by cakeslob on topic How to adapt the extended IO?
Hey chen, I also have a PCF8574. I havent tried to use it yet, but gathered resources and examples related to i2c expander.
This one is for DAC/ temp sensor,
github.com/bosston88/LinuxCNCRPi/blob/master/mcp3421.c
github.com/bosston88/LinuxCNCRPi/blob/master/mcp3421.h
github.com/bosston88/LinuxCNCRPi/blob/master/si7021.c
This is for different i2c io expander
github.com/bosston88/LinuxCNCRPi/tree/master/archive
github.com/sleepybishop/linuxcnc/blob/fi...hal/user_comps/i2c.c
github.com/sleepybishop/linuxcnc/blob/fi...user_comps/sx1509b.c
Last edit: 09 Aug 2022 18:33 by cakeslob.
Time to create page: 0.291 seconds
