Index-Input instead of Index-enable signal
- Thank you received: 5336
19 Aug 2022 15:28 - 19 Aug 2022 15:31 #250088
Replied by PCW on topic Index-Input instead of Index-enable signal
If Implemented in hal, the basic idea would be to
set spindle-sync true, do a slow velocity spindle rotate
until spindle-sync becomes false and then run the orient
cycle.
It would be nicer if this was implemented in the orient
component, and better still LinuxCNC, but a hal
implementation should work identically.
cycle.
Last edit: 19 Aug 2022 15:31 by PCW.
03 Sep 2022 05:08 #251092
Replied by andypugh on topic Index-Input instead of Index-enable signal
A kludgy way to do this in the Gcode is with a very tiny G33.1 move at low spindle speed. That will reset the encoder to the index.
Time to create page: 0.766 seconds
