error message when starting my first machine
4 years 1 month ago - 4 years 1 month ago #252868
by millathe
error message when starting my first machine was created by millathe
Hi all,
when starting "my_first_machine" created by pncconfig. LinuxCNC stopps and creates the following error message
(g-file-error-quark: file could not be opened - file not found <-- translated into english since it is printed in german):
Found file(REL): ./meine_erste_LinuxCNC-Maschine.halFound file(REL): ./custom.halStarting TASK program: milltaskStarting DISPLAY program: axishalcmd loadusr -Wn gladevcp gladevcp -c gladevcp -t Systemthema folgen -H gvcp_call_list.hal -x {XID} gvcp-panel.ui[False]g-file-error-quark: Datei »folgen« konnte nicht geöffnet werden: Datei oder Verzeichnis nicht gefunden (4)Embeded tab command "halcmd loadusr -Wn gladevcp gladevcp -c gladevcp -t Systemthema folgen -H gvcp_call_list.hal -x 96469426 gvcp-panel.ui" exited with error: 1Shutting down and cleaning up LinuxCNC...Running HAL shutdown script _____________________________________________________________________________
this is the part of .ini:
fileEMC]MACHINE = meine_erste_LinuxCNC-MaschineDEBUG = 0VERSION = 1.1 [DISPLAY]DISPLAY = axisEMBED_TAB_NAME = GladeVCPEMBED_TAB_COMMAND = halcmd loadusr -Wn gladevcp gladevcp -c gladevcp -t Systemthema folgen -H gvcp_call_list.hal -x {XID} gvcp-panel.uiPOSITION_OFFSET = RELATIVEPOSITION_FEEDBACK = ACTUALMAX_FEED_OVERRIDE = 2.000000MAX_SPINDLE_OVERRIDE = 1.000000MIN_SPINDLE_OVERRIDE = 0.500000INTRO_GRAPHIC = linuxcnc.gifINTRO_TIME = 5PROGRAM_PREFIX = /home/gerhard/linuxcnc/nc_filesPYVCP = pyvcp-panel.xmlINCREMENTS = 5mm 1mm .5mm .1mm .05mm .01mm .005mmPOSITION_FEEDBACK = ACTUALDEFAULT_LINEAR_VELOCITY = 6.000000MAX_LINEAR_VELOCITY = 25.000000MIN_LINEAR_VELOCITY = 0.500000DEFAULT_ANGULAR_VELOCITY = 12.000000MAX_ANGULAR_VELOCITY = 180.000000MIN_ANGULAR_VELOCITY = 1.666667EDITOR = geditGEOMETRY = xyzCYCLE_TIME = 100
Thanks and best Regards
Gerhard
Gerhard
Last edit: 4 years 1 month ago by millathe.
4 years 1 month ago #252916
Replied by Aciera on topic error message when starting my first machine
You seem to have a space in the filename between "Systemthema" and "folgen" in this line:
Spaces in filenames are problematic so you might want to use something like an underscore '_' instead.
The following user(s) said Thank You: tommylight, millathe
4 years 1 month ago #253021
by millathe
Replied by millathe on topic error message when starting my first machine
Hi Aciera,
this was the root cause for this problem!
Thank you!!!
Thank you!!!
