5 axis foam cutter machine hal
12 Oct 2022 04:18 - 12 Oct 2022 04:47 #254009 by Whoopie
5 axis foam cutter machine hal was created by Whoopie
Hi all,
I'm totally new to LinuxCNC and i have a question about kinematics. I'm building 5 axis (in the Cartesian system) foam cutter (two independent X axes, two independent Y axes and rotational axis) and i wonder about kinematics of the machine. I know people use trivkins for 4 axis machines, but can i also use trivkins in my case? Maybe someone here on the forum built such a machine?
Last edit: 12 Oct 2022 04:47 by Whoopie.
19 Oct 2022 18:30 #254572 by andypugh
Replied by andypugh on topic 5 axis foam cutter machine hal
LinuxCNC supports an XYUV config for foam cutters, is that anything like your machine?
linuxcnc.org/docs/html/gui/axis.html#_us...in_foam_cutting_mode
Time to create page: 0.638 seconds
