ArduinoIO HAL component
3 years 6 months ago #268647
by rhyno440
Replied by rhyno440 on topic ArduinoIO HAL component
sorry here is the attached report
Ryan
Ryan
3 years 6 months ago #268661
Replied by tommylight on topic ArduinoIO HAL component
Search for arduino permission denied, look for " add uses to dialup group"
And also, just in case
sudo apt purge brltty
The following user(s) said Thank You: dinodf
3 years 6 months ago #268694
by dinodf
Replied by dinodf on topic ArduinoIO HAL component
to connect to Arduino you need to add the user to dialout group,
also have to set the execute flag to ArduinoIO
and need to have installed python-serial
sudo usermod -a -G dialout rhyno
sudo chmod +x ArduinoIO
sudo apt-get install python-serial
3 years 6 months ago #268709
by rhyno440
Adding me to the group dialout seems to have worked.
I also noticed I needed to switch from ttyACM0 to ttyUSB0 in arduinoIO since I am using an arduino UNO.
I really appreciate the help, this is going to help with my control panel.
Thanks again!
Ryan
Thanks again!
Ryan
3 years 6 months ago - 3 years 6 months ago #268880
by rhyno440
Hi again guys, sorry for being a noob at this.
I have a question about the python section.
How do I adjust the number of pins?
I have a mega 2560 and would like to use as many digital inputs and outputs as possible.
adjustments to the arduino sketch don't seem to have an effect, and trying to adjust the number of inputs and outputs in the python script just causes it to no longer show in Halshow. Do i need to change both the sketch and the python?
thanks in advance
Ryan
thanks in advance
Ryan
Last edit: 3 years 6 months ago by rhyno440.
3 years 6 months ago #269000
by rhyno440
Thought I would post an update.
I did finally sort this out, I currently have 16 input and outputs.
I started in the Arduino IDE and properly ID pins as input or output.
Then update the python script to reflect the number of each.
I do still have the occasional problem with the outputs.
i can have 7 outputs, 8 outputs or 16 outputs.
Trying to have 9, 10 or 18 outputs causes the hal component to not show in halshow.
At this point this will work, I needed 12 outputs for LEDs.
Pretty simple in hind sight, but I'm still pretty new to coding at this level.
Thanks again for the code, this makes my custom control panel a reality.
Ryan
Ryan
Time to create page: 0.254 seconds
