Signal link problem
25 Nov 2022 05:32 #257614 by CNC_Tux
Signal link problem was created by CNC_Tux
Dear Community,
i have a problem with the signal link in the hal.
I use LinuxCNC 2.8.4 with MESA Card 7i76E and Gmoccapy with a XHC_WHB06B with the standard for the pedant.
All things are very well running, but i need some signal links about the modes Automatic and Manual
I try the make the link like " net ba-man halui.mode.is-manual" i got a message: Pin "halui.mode.is-manual" was already linked to signal "pdnt.mode.is-manual".
If i try "net ba-man  pdnt.mode.is-manual" i got a message: Pin "pdnt.mode.is-manual" does not exist.
If i try "net ba-man  whb.halui.mode.is-manual" i got a message: "Pin "whb.halui.mode.is-manual" was already linked to signal "pdnt.mode.is-manual"
I dont know whats wrong!?
If know someone a souloution, please let me know.
Thank you so much in advance
Cheers
Reinhard
25 Nov 2022 05:51 - 25 Nov 2022 05:53 #257615 by HansU
Replied by HansU on topic Signal link problem
You can't connect one pin to several nets (=signals) and you can't connect one net to another.
Which pins do you want to connect?
I guess halui.mode.is-manual to whb.halui.mode.is-manual?
So according to your error message a signal named "pdnt.mode.is-manual" exists with the pin "halui.mode.is-manual" linked to.
So I guess
net pdnt.mode.is-manual <= whb.halui.mode.is-manual
would do the trick without having seen your HAL file.
Last edit: 25 Nov 2022 05:53 by HansU.
25 Nov 2022 08:59 #257625 by CNC_Tux
Replied by CNC_Tux on topic Signal link problem
Hello HansU
the halui.mode.is manual is linked in the hal of XHC_WHB06B
The line looks like this:
"net whb.halui.mode.is-manual pdnt.mode.is-manual halui.mode.is-manual"
I need a signal from mode.is-manual to a output pin.
Nothing will work, an i dont have any idea how can make this link.
Cheers
Reinhard
25 Nov 2022 09:44 #257627 by HansU
Probably
net whb.halui.mode.is-manual => your_output_pin
Otherwise please post yout HAL file(s).
25 Nov 2022 16:16 - 25 Nov 2022 16:17 #257648 by chris@cnc
Replied by chris@cnc on topic Signal link problem
I also struggle with this pin. Line 44 in the file. line 43 is the original.
For some reason, the standard hal was not working. Here is my whb.hal
near similar to the original with some personal notes. Hope it helps
Last edit: 25 Nov 2022 16:17 by chris@cnc.
26 Nov 2022 02:54 #257668 by CNC_Tux
Good morning Chris,
thank you so much for your HAL and support, i will try directly on Monday.
Cheers
Reinhard
Time to create page: 0.326 seconds
