When to use Motion and when to use halui
08 Dec 2022 09:29 #258894 by frogandspanner
When to use Motion and when to use halui was created by frogandspanner
I am confused by two examples with which I have been working, and I referred to them in another posting
MPG Handwheel - how to make it operate when linuxCNC/axis not homed
In the code wiki.linuxcnc.org/cgi-bin/wiki.pl?Hooking_Up_A_MPG_Pendant jogging is carried out using what I understand is Motion in such hal as net pend-counts axis.0.jog-counts <= encoder.0.counts
but the code for using a Joypad at wiki.linuxcnc.org/cgi-bin/wiki.pl?Simple_Remote_Pendant
action is via halui in lines such as
net jog-x-analog <= mux2_x.out => mux2_x.in0 halui.joint.0.analog halui.axis.x.analogWhy does one use motion, the other halui.
08 Dec 2022 10:29 #258897 by rodw
Replied by rodw on topic When to use Motion and when to use halui
The joypad is not real time as its connected by USB.
The MPG uses an encoder so its real time
halui is a userspace non real time component
Motion is real time
expand man pages on the docs page will list the user space components followed by the real time components
08 Dec 2022 11:33 #258901 by frogandspanner
Replied by frogandspanner on topic When to use Motion and when to use halui
So is halui an interface between userspace and kernel/real-time?
I am a little unclear as to what you mean by "expand man pages on the docs page".
A url would help this ignoramus.
08 Dec 2022 18:36 - 08 Dec 2022 18:37 #258946 by andypugh
Replied by andypugh on topic When to use Motion and when to use halui
Here:
linuxcnc.org/docs/stable/html/
And:
Last edit: 08 Dec 2022 18:37 by andypugh.
Time to create page: 0.694 seconds
