here is the current switch statement, couldn't get the ternary logic to work right. so went back to the drawing board. here is the conversation with chat gpt, walking through the code, as I read it this also appears to be the case, but I am absolutely certain there is some kinda quirky problem within linuxcnc at this point that is making me chase my tail. I have not tested this latest revision, but man, chat gpt makes it super easy to rewrite, iterate and explore code logic. If only it was netting me the desired results, but I am actually kinda enjoying learning C with chat gpt, and I hate programming. tedious and slow. not my kinda work. the problem is that the code stops executing at the end of the decoding for the pocket with the bcd switches, and I have no idea why.
Sure! Let's go through the code step by step:
The first line defines an enumerated type called ToolChangeState, which is used to represent the different states that the tool change process can be in. The possible states are INIT, SELECT_TOOL, MOVE_TO_TOOL, CHANGE_TOOL, FINISHED, and ERROR.
The next line initializes a variable called progress_level to the value INIT, which is the first state of the tool change process.
The if statement checks if the toolchange flag is set. If it is, then the program will enter the switch statement. If it is not set, then the program will skip the switch statement and continue with the rest of the code (if any).
The switch statement checks the value of progress_level and executes the corresponding block of code for that state.
In the first case (INIT), the program checks if the tool number is between 1 and 6. If it is, then the progress_level is set to SELECT_TOOL. If it is not, then an error message is printed and the progress_level is set to ERROR.
In the second case (SELECT_TOOL), the program checks if the tool number is not equal to the current pocket. If it is not, then the progress_level is set to MOVE_TO_TOOL. If it is equal, then the toolchanged flag is set to true, signaling that the tool change process is finished.
In the third case (MOVE_TO_TOOL), the program sets the unlock flag to true and waits for 1 second. It then sets the motor flag to true and enters a loop. The loop will continue until the motor flag is set to false. Inside the loop, the program checks if the current pocket is equal to the tool number. If it is, then the motor flag is set to false and the loop is exited. The program also checks if the loop has been running for more than 10 seconds. If it has, then an error message is printed, the motor flag is set to false, and the progress_level is set to ERROR.
After the loop, the program waits for 2 seconds and then checks if the strobe flag is set and the current pocket is equal to the tool number. If both conditions are true, then the unlock flag is set to false and the toolchanged flag is set to true, signaling that the tool change process is finished. If either condition is not true, then an error message is printed.
In the fourth case (ERROR), the program does nothing. This case
