EMC on friendlyARM mini2440
- jaydeep.gajjar90
i have built a cnc mill using emc2 from my computer. now i want to run my mill by FriendlyARM mini2440.
How can i convert or change parallel port settings to GPIO of ARM board ?
Any Suggestions ?
Thanks in Advance....................
- Thank you received: 5013
You would then need a hal realtime driver for the gpio pins.
- jaydeep.gajjar90
i have checked the file "hal_parport.c" in source directory.......
it has three operations : parport.0.read , parport.0.write etc
if i want to create a gpio hal driver then, specifically which driver files are required to build or modify ?
because i have no idea about parallel port HAL files.....
Waiting for reply ................
Thanks again.........
- jaydeep.gajjar90
the kernel works perfectly,
but when i tried to compile emc2 source it gives error about parport as no such hardware.........
now what have to do ?
create the gpio drivers first or try to change parport drivers ?
if i change the base address of parport to base address of gpio then it will work or not ? ........
Does the RTAI latency test run? What numbers do you get?
- aike
- Thank you received: 4
Yes!As an experiment, just delete all references to the parport in the Makefile then compile.
I also want to recocnize this!
- blkbagger
I have programmed in various languages including C++. C#, VB.net, and VB Pro for nearly 25 years..
I have extensive experience with EMC running on a PC and a Sherline CNC mill setup, I am now moving into development of my own system to offer to others and I am exploring embedded systems as an option for a particular machine...
Ken
- vmarkiv
- whhenyuan
www.hycshop.com/
Admittedly that's $88 but that includes the LCD screen. The mini2440/micro2440 is a brilliant way to get into ARM9 based Linux
development!
