changing ethercat SDOs using user panel
3 years 7 months ago #266184 by mehdidadash
is it posible to change drives SDOs using user panel ?
i mean, sending a comand using hal
for example :
a button that sends this comand :
ethercat upload -t int32 -p 0 0x2001 0 0
3 years 7 months ago #266284 by andypugh
Maybe....
You can set buttons that set a HAL pin to run MDI commands, then the MDI command can be a user-defined M-code that can be any executable file. It's a bit convoluted, but it works.
linuxcnc.org/docs/stable/html/config/ini....html#_halui_section
and
linuxcnc.org/docs/stable/html/gcode/m-code.html#mcode:m100-m199
Alternatively the GladeVCP and probably QTVCP allow you to embed code directly in the button.
linuxcnc.org/docs/stable/html/gui/gladev...on_widgets_reference
And, any normal UI element can call handler code in the backend file to do the same thing, possibly with the Python os.system("ethercat upload -t int32 -p 0 0x2001 0 0")
Or, you could use a custom HAL component (I wuld probably use Python Userspace) that has HAL pins that connect to the buttons and sends the commands when the pin values change. This approach would (probably) work best for physical hardware buttons, though the MDI_COMMAND approach can also work that way.
3 years 7 months ago #266488 by rodw
My understanding is in the ethercat world SDOs are set on startup and PDOs can be dynamically changed.
So it not possible to change SDOs at runtime
3 years 7 months ago #266791 by mehdidadash
Thank you. It will help for sure.
3 years 7 months ago #266792 by mehdidadash
The idea came to my mind after i find this :
github.com/sittner/linuxcnc-ethercat/blo...c/lcec_deasda.c#L175
Ecrt_slave_config_sdo8
Changes 0x6060 sdo in delta asda c file.
3 years 7 months ago #266808 by db1981
these lines are executed at config time (preop state), in front of starting the realtime thread (op state) .
You can readout sdos per terminal everytime, for writing there is more complex code needed.
github.com/steup-engineering/linuxcnc-et.../lcec_class_rt_sdo.c
github.com/steup-engineering/linuxcnc-et.../src/lcec_nanopd4e.c
this is an slave, where i added all neccesary pdos for drive tuning/setup , to change them online from lcnc.
With etherlab master you have to know which sdos you want to access and must add memory addresses for them at setup state....
The following user(s) said Thank You: mehdidadash
Time to create page: 0.178 seconds
