- Thank you received: 88
HAL M19 Orient dont work
3 years 7 months ago #266688
by 0x2102
Replied by 0x2102 on topic HAL M19 Orient dont work
Remove the # you mentioned (spindle-sync) just to be safe.
Start LinuxCNC and monitor in HAL spindle.0.index-enable (should be true/on). Turn the spindle by hand until it's off to verify LinuxCNC can see the Index signal.
What are your Spindle PID settings (.ini)?
You can start with something like this:
[SPINDLE_0]
# PID Setting
P = 10
I = 0
D = 0
FF0 = 0
FF1 = 1
FF2 = 0
Play with the P value. Decrease or increase and monitor the changes.
[SPINDLE_0]
# PID Setting
P = 10
I = 0
D = 0
FF0 = 0
FF1 = 1
FF2 = 0
3 years 7 months ago #266694
Replied by andypugh on topic HAL M19 Orient dont work
This diagram shows how orient can be connected, and is also updated with the current spindle pin names.
wiki.linuxcnc.org/uploads/orient.svg
3 years 7 months ago #266710
by Stefan321
Replied by Stefan321 on topic HAL M19 Orient dont work
I have the index signal, I've tested it in the past, I've already drilled threads with the old config without compensation. but can still look up the exact name of the pin to rule out errors. thanks for the visual image of the pin assignment, I'll take a close look at it tomorrow.
3 years 7 months ago #266766
by Stefan321
so I adjusted my spindle today, it now runs wonderfully in speed mode. m19 position mode still not working. (G33.1 works) I tested. Index is there too.
The pins for Orient also work, except for Sync, and accordingly there is no pinout for Position Reached.
What I also noticed is the pen for
spindle.0.on <- not working spindle.1.on <- speed
Spindle.2.on <- position
3 years 7 months ago - 3 years 7 months ago #267074
How many spindles do you actually have?
And have you done any PID tuning of the position feedback loop?
Last edit: 3 years 7 months ago by andypugh.
3 years 7 months ago #267431
by Stefan321
Well, the last few days I unfortunately didn't have any time, today I looked at it again but still can't get any further. I adjusted the pid. but brings no improvement. In addition, when I make m19 r0, the spindle rotates abnormally high, I can adjust that somewhere. so the speed at m19? I also set the sync manual enable times. this signal then goes out after one revolution
Time to create page: 0.321 seconds
