HAL M19 Orient dont work
3 years 7 months ago #267697
by Stefan321
Replied by Stefan321 on topic HAL M19 Orient dont work
unfortunately I don't have time to continue testing until the weekend.
I'll definitely throw out the delay part. since my spindle is also very sluggish. whether m19 or g33.1.
With the automatically generated per wizard, that was not.
3 years 7 months ago #268024
by Stefan321
So I still haven't gotten any further, but now I understand the offset, it's like this, it's referenced once at the beginning and then not anymore. if the spindle is now, for example, at 1.8787 revolutions, the 1 is stored in the cmd + the offset, which is a 1 here, you could also write 2 or whatever, so we would be at 1+1=2 so it must/should keep spindle at 2 with m19 r0.
unfortunately it doesn't do that for me, it lags behind / sluggishly. the orient-pid continues to print a step.
# pwm signal from either motion or orient
net pwm-switch-in0 spindle-pwm-switch.in0 <= spindle-ramp.out
net pwm-switch-in1 spindle-pwm-switch.in1 <= spindle-pid.output
net pwm-switch-out spindle-pwm-switch.out => [HMOT](CARD0).stepgen.04.velocity-cmd
i think here
# If the target position is the same as the actual position, then move the bit in motion from near
net spindle-pos-err spindle-at-pos.in2 <= spindle-pid.error
net spindle-at-pos spindle-at-pos.out =>
net spindle-on0 spindle.0.on => spindle-active-delay.in
net spindle-on1 spindle-active-delay.out => or2.0.in0 => not.0.in
net spindle-on2 and2.0.in0 <= not.0.out
# Enable orient and pid
net orient-active and2.0.out => or2.0.in1 => spindle-pwm-switch.sel
net orient-active => spindle-pid.enable => spindle-orient.enable
net spindle enable or2.0.out => [HMOT](CARD0).stepgen.04.enable
the worm must be inside somewhere. spindle-on2 is my orient. This actually has to be deactivated when the position is reached. spindle itself, i.e. spindle-enable, must remain active. so that the spindle remains fixed. But how do I do that?
i think here
3 years 6 months ago #268536
by Stefan321
so I got a little further, first I had the problem that my spindle with g33.1 runs behind for an extremely long time, so I have net
spindle-pos-rowcounts <= [HMOT](CARD0).encoder.04.rawcounts
inserted, now the g33.1 runs very clean again.
to the m19, it doesn't work the way it should
have now
into changed
net spindle-at-pos spindle-at-pos.out => not.0.in
net spindle-on1 spindle-active-delay.out => or2.0.in0 => #not.0.in
. the spindle stops, however, if it skips the sweet point, it needs an extra round
have now
into changed
3 years 6 months ago #269074
Replied by andypugh on topic HAL M19 Orient dont work
Sorry, just trying to catch up with the forum. Is this working yet?
3 years 6 months ago - 3 years 6 months ago #269107
by Stefan321
so, talla83 made a new video about linux 2.8 +, 5 days ago. With the new setup, things are looking pretty good. However, once I have the problem that the spindle wobbles back and forth with the P500. my other problem is that by turning the spindle quickly, the index is lost. So I would either have to build an encoder directly on the spindle, which then replaces the npn sensor, or I have to set index to enable. preferably by S50 m3
g33.1 k0.1 z0. That is enough.which is also another problem if I cut thread g33.1 z-5 k1 then the spindle moves me 2mm lower and when driving out again also 2mm higher koriegirt but then down the 2mm again. more speed the worse
emotionally, the spindle has become very sluggish since orient has been available. I made the comparison again with the auto config. everything was very direct
Last edit: 3 years 6 months ago by Stefan321.
3 years 6 months ago #269141
Do you have both a position and a velocity PID now? You probably need to tune the velocity PID. Firstly by using an FF0 of 1.0, I would imagine. (Basically zero everything except FF0 first, then adjust FF0 to give the correct speed in the middle of the range.
Time to create page: 0.214 seconds
