Warning: File contains DOS-style line endings.
25 May 2023 09:54 #272152 by Wayner
I am  a newbee to LInux CNC. I need some help getting past the  "Warning: File contains DOS-style line endings."
I am trying to configure LInuxcnc to work with a VistaCNC P4 S pendant. I keep getting the error "Warning: File contains DOS-style line endings."
I have saved the file vc-ps4.hal in linux but the error still comes up. I have looked at the file in Notepad++ and it has CRLF after each line.
Is there a specific file format I need to save the file in?
Thanks in advance for any help.
Wayne
25 May 2023 12:45 #272159 by JPL
Dos/windows style is CR + LF
Linux (Unix) style is LF only.
That can be quickly changed when using notepad++ or programmer's notepad.
25 May 2023 15:21 #272168 by rodw
There is a command line program called dos2unix which will clean it up
You will need to install it with: sudo apt install dos2unix
If you must open a file on Windows, use notepad++ and ensure the line endings are set for linefeed only in the settings.
25 May 2023 15:45 #272170 by Wayner
Thanks I was able to make the change with Notepad++.
25 May 2023 16:40 #272173 by snowgoer540
Replied by snowgoer540 on topic Warning: File contains DOS-style line endings.
You can use geany in Linux to change it as well.
Note that if you email the file to yourself, sometimes Google chrome sees fit to change the line endings (assuming during its virus scan). At least it used to.
26 May 2023 20:09 - 26 May 2023 20:11 #272240 by Wayner
I got P4-s working with my PC's running linuxcnc 2.6.11- unbutu12.04.
I cant seem to get it to work with my LinuxCNC 2.84-buster.
Im getting Debug error "vc-postgui.hal:6: Pin 'ini.4.max_velocity' does not exist"
Note: Using POSIX realtime
note: MAXV max: 25.000 units/sec 1500.000 units/min
note: LJOG max: 25.000 units/sec 1500.000 units/min
note: LJOG default: 0.200 units/sec 12.000 units/min
note: AJOG max: 25.000 units/sec 1500.000 units/min
note: AJOG default: 25.000 units/sec 1500.000 units/min
note: jog_order='XYZA'
note: jog_invert=set()
2183
2218
Stopping realtime threads
Unloading hal components
Last edit: 26 May 2023 20:11 by Wayner. Reason: typo's
26 May 2023 22:12 #272241 by JohnnyCNC
Replied by JohnnyCNC on topic Warning: File contains DOS-style line endings.
Mine is working under 2.8.4.  This is the contents of my vc-postgui.hal
net axis_0_max_vel vc-p4s.ini.0.max.vel => ini.0.max_velocity
net axis_1_max_vel vc-p4s.ini.1.max.vel => ini.1.max_velocity
net axis_2_max_vel vc-p4s.ini.2.max.vel => ini.2.max_velocity
net axis_3_max_vel vc-p4s.ini.3.max.vel => ini.3.max_velocity
net axis_4_max_vel vc-p4s.ini.4.max.vel => ini.4.max_velocity
net axis_5_max_vel vc-p4s.ini.5.max.vel => ini.5.max_velocity
net spindle-speed hm2_5i25.0.encoder.00.count
In my vc-p4s.hal I only have 3 axis setup
setp axis_0_max_velocity [JOINT_0]MAX_VELOCITY
setp axis_1_max_velocity [JOINT_1]MAX_VELOCITY
setp axis_2_max_velocity [JOINT_2]MAX_VELOCITY
I don't know if any of this will help.  Maybe you could comment it out if you don't have that many axis.
27 May 2023 06:31 #272260 by Wayner
Our files are the same except for line "net spindle-speed hm2_5i25.0.encoder.00.count"
I commented out axis 4 and 5, the app loads. The pendant is now working.
I had previoulsy commented out line 5.
Thanks for your help,
Wayne
27 May 2023 17:03 #272292 by JohnnyCNC
I'm using a 1.8kw servo motor as a spindle and it has an encoder so that is what the extra line in mine is for.
I wonder why I don't get the error you were getting? I only have a mill with XYZ. Oh well, I guess if it works don't break it.
28 May 2023 11:06 #272346 by Wayner
Im using Axsis 4 axsis GUI. That may be why I had to comment out the 5th and 6th axsis.
So far I can't get Gmoccapy gui to work.
Thanks again for your insight and help. This is my first attempt at installing Linuxcnc. My previous version was pre installed by Sherline.
Wayne
