mesa board 7i77 digital out 4-5-10-11-12-13-14-15 always down
- bkt
- Thank you received: 114
31 Jul 2023 01:17 #276608
by bkt
mesa board 7i77 digital out 4-5-10-11-12-13-14-15 always down was created by bkt
a lot of time that nor work on mesa 7i77 ... but check today that output 4, 5 and than 10, 11, 12, 13, 14 ,15 not work not on axis show pin not in hardware .... but on TB2 pin 1-2-3-4 is on +24V dc ... pi5-6-7 is disconnect and pin8 is to gnd. so not understand what happens .... some suggest?
thanks
bkt
thanks
bkt
- JPL
- Thank you received: 118
31 Jul 2023 06:18 #276617
by JPL
If you mean the pins do not show in 'show HAL configuration' then this may be because you did not flash the FPGA card (5i25?) with the correct firmware configuration file. You also need to make sure you have 24v for the field voltage. I/O Pins do not show when field voltage is not connected.
Did you flash the fpga (5i25) with mesaflash?
Is your 7i77 card connected to a 5i25?
Do you have 24v field voltage?
Replied by JPL on topic mesa board 7i77 digital out 4-5-10-11-12-13-14-15 always down
... 10, 11, 12, 13, 14 ,15 not work not on axis show pin not in hardware ....
- Thank you received: 7504
31 Jul 2023 06:50 #276620
Replied by tommylight on topic mesa board 7i77 digital out 4-5-10-11-12-13-14-15 always down
Do the outputs have relays wired directly? Do those relays have diodes in parallel with the coil?
Picture of the wiring might help.
- bkt
15 Aug 2023 03:41 #278033
by bkt
Replied by bkt on topic mesa board 7i77 digital out 4-5-10-11-12-13-14-15 always down
because old board ... maybe connection on tb2 was oxidated because when change shortcut for pin 1-2-3-4 all run again.
thanks to all
thanks to all
Time to create page: 0.295 seconds
