Reuse signal in postgui hal file
3 years 1 week ago #283461 by Guglielmi
Hello,
I would like to show the spindle frequency on my HMI.
The frequency is read through modbus and it's linked already to a signal "actual_speed", I use it to perform some check in ladder..
Well, in postgui, I would like to use the same signal and link it to a HALLabel.
It's possible to reuse the signal defined in the HAL file into postgui HAL?
Should I copy it in a ladder pin?
Bye
Andrea
3 years 1 week ago #283469 by tommylight
Probably yes, give it a try, LinuxCNC is pretty good at pointing out errors.
3 years 1 week ago #283483 by Guglielmi
Of course I tried a lot before write.. so just reusing the signal doesn't work, in postgui raises an error for signal not existing, I tried also to use a classicladder variable even it's not a nice solution without find a way.
I searched a lot in HAL documentation and on the web looking for a kind of syntax to define signal global.. nothing.
I had the idea to move all related to spindle frequency in the postgui.. maybe in this way it works but I'm also curious to know if it's possible.
So I wrote the post.
Code in the mail HAL:
net speed_in conv-s32-float.0.in <= classicladder.0.s32out-03 net actual_speed conv-s32-float.0.out => spindle.0.speed-in net actual_speed => near.0.in2 classicladder.0.floatin-00
Code in postgui HAL:
net SpindleFreq classicladder.0.floatin-00 => AG_CncHmi.lblFreq
It doesn't work, error:
hmi_postgui.hal:31: Pin 'classicladder.0.floatin-00' was already linked to signal 'actual_speed'
but again here I'm trying to use floatin-00, I prefer to use actual_speed directly if possible.
Andrea
3 years 1 week ago #283484 by chris@cnc
net actual_speed => near.0.in2 classicladder.0.floatin-00 AG_CncHmi.lblFreq
Does this work?
3 years 1 week ago #283485 by Guglielmi
The problem is that  AG_CncHmi.lblFreq is a label of my HMI so it should be handled in postgui,
this line of code is in the main HAL ...
3 years 1 week ago #283488 by rodw
That is not a problem. Using a postgui file just changes the order of hal loading. Its still updated in real time, but the gui may not refresh immediately.
Alternatively, use this in your postgui
net actual_speed => AG_CncHmi.lblFreq
The following user(s) said Thank You: Guglielmi
Time to create page: 0.344 seconds
