Reuse signal in postgui hal file
3 years 1 week ago #283492 by Guglielmi
Thanks for answer.
the order of call is the correct one if I'm not wrong:
HALFILE = cnc3040.hal # list of halcmd commands to execute # commands are executed in the order in which they appear #HALCMD = save neta # Single file that is executed after the GUI has started.  Only supported by # AXIS at this time (only AXIS creates a HAL component of its own) POSTGUI_HALFILE = hmi_postgui.hal
So the postgui is called after.. the order you mean the order inside the ini, right?
I tried your line of code and it works.. incredible because it was the first I try.. or most probably the mistake is
that I tried with:
net SpindleFreq actual_speed => AG_CncHmi.lblFreq
maybe it is considered differenty.. I got this error:
hmi_postgui.hal:27: Pin 'actual_speed' does not exist
that confused my.. "does not exist" it's not really true. It works just removing SpindleFreq signal..
Perfect! Tanks a lot rodw!
Time to create page: 0.215 seconds
