Problem with config files
- roudee
06 Dec 2023 18:56 #287400
by roudee
Problem with config files was created by roudee
Hello
I am new in linuxcnc world, so please forgive me my ignorance. I was struggling with configuring my PrintNC and Linuxcnc to work. I got many errors "no parport registered at 0x378" , latency problems, pns... I managed to run all axises proprly, and spindle using vfd. Few days ago added RS485 usb and trying to configure it without success. Changed my hall and ini files to work with cloned Y axis, but ihave now 0 1 2 3 insteed X Y Z, and now Y is going in opposite direction while homing. I can run spindle , change direction, but can't change its speed. Getting grey hairs after 20 hours
Please help me to configure my dreamed cnc. Added my config files, maybe someone will figure out what is wrong.
Thank You in advance.
- Thank you received: 7504
06 Dec 2023 19:05 #287405
Replied by tommylight on topic Problem with config files
Do both Y move in the wrong direction or just one of them?
The following user(s) said Thank You: roudee
- roudee
07 Dec 2023 02:19 #287419
by roudee
Replied by roudee on topic Problem with config files
both Y
07 Dec 2023 05:36 #287434
Do they move in the wrong direction when jogging?
If they move in the wrong direction both when jogging and homing = change the scale in the ini file for the Y axis to negative by adding - in front of the value.
If they move in the wrong direction only while homing, add - in front of HOME_SEARCH_VELOCITY. This might also need to do the same for HOME_LATCH_VELOCITY.
- roudee
07 Dec 2023 10:07 #287458
by roudee
Yes, they move in wrong direction. I will check when get home changes. Thank You very much
- roudee
07 Dec 2023 12:27 #287473
by roudee
Here is also ini file...
Time to create page: 0.209 seconds
