CL75T Closed Loop Stepper Driver Alarm Reset Signal
- Trevy3
05 May 2024 18:20 - 05 May 2024 18:22 #299859
by Trevy3
CL75T Closed Loop Stepper Driver Alarm Reset Signal was created by Trevy3
I have a CL57T closed loop stepper driver with alarm output. I have the alarm wired to input 4 and 5 on my 7i96s and it works fine.
Lines 257-267 in HAL:
# ---estop signals---
net estop-ext => iocontrol.0.emc-enable-in
net estop-out => hm2_7i96s.0.gpio.045.in_not
# --- drive ALM ---
net x-fault => joint.0.amp-fault-in <= hm2_7i96s.0.inm.00.input-05
net z-fault => joint.1.amp-fault-in <= hm2_7i96s.0.inm.00.input-04
net x-fault => joint.0.amp-fault-in halui.joint.0.unhome
net z-fault => joint.1.amp-fault-in halui.joint.1.unhome
My issue is resetting the alarm after it triggers. At the moment, I need to close Lcnc and reopen it to get it to send a new "net x-enable <= joint.0.amp-enable-out" signal. I attempted to follow This Post but couldn't get it to work. Could I get some direction with this?
# --- drive ALM ---
Last edit: 05 May 2024 18:22 by Trevy3.
- Thank you received: 7504
05 May 2024 19:53 #299865
Last two lines ... why? And again, why?
Drive enable should be controlled by amplifier-enable or machine-is-enabled or x-enable or y-enable or..., not by e-stop
Drives should reset when disabled and enabled again, so there is nothing except the lines i did not quote and one of the above pins to enable the drives.
Replied by tommylight on topic CL75T Closed Loop Stepper Driver Alarm Reset Signal
First line should be output, not input pinnet estop-out => hm2_7i96s.0.gpio.045.in_not
- Thank you received: 5336
05 May 2024 20:10 #299866
Replied by PCW on topic CL75T Closed Loop Stepper Driver Alarm Reset Signal
How do you reset the drives?
I would think this needs a spare 7I96S output
05 May 2024 20:31 #299870
Gecko drives require an input and an output to reset/fault, the use the same pin for both.
LAM Technologies need just the enable pin, fault disables drives, enabling them resets them.
Literally, just pressing F2.
- spumco
- Thank you received: 905
05 May 2024 20:56 #299872
by spumco
Replied by spumco on topic CL75T Closed Loop Stepper Driver Alarm Reset Signal
Those stepper drives have no reset function.
You done necessarily need to restart LCNC, but you must power cycle them to reset the alarm state.
Note that the motors are very likely to 'jump' a little bit when the bus power is turned off/on. Unless you have linear scales on the axes, I'd strongly suggest configuring your LCNC arrangement to require a re-home if an axis faults.
Time to create page: 0.491 seconds
