I can´t get a motor to stop: stepper motor + encoder
  • tovarna
  • Topic Author
  • New Member
  • New Member
2 years 5 months ago - 2 years 5 months ago #299939 by tovarna
I have a Mesa 7i95 with, so far, 2 stepper motors and encoders and I plan to use it on an old plasma machine.
Already set the software over linuxcnc 2.9 and I got the motors to run (I changed the original servos for some steppers, I know I might go back to servos, but this was what I had around and wanted to try them before spending extra bucks).
Long story short, I got to move in both axis but the enconder of one of the axis (the other is not well configured or wired) never finds the position it seeks. Hope a video explains:
video of my issue
X axis, I did not get the encoder to work.
Y axis, is the one in the video that moves all the time
(Yes, I might have named them the other way around).
Plasma.ini and plasma.hal attached
1- I do not know what to change in order to that motor to stop when searching its position
2- I do not know what I did wrong in the other axis, because it is not reading the encoder.
Could be that some wiring and or encoder to be not working properly...but I do think it is more my mistake in setting the .ini and .hal.
Any piece of advice is much appreciated.
Thanks,
Javier
Last edit: 2 years 5 months ago by tovarna.
2 years 5 months ago - 2 years 5 months ago #299944 by PCW
setp pid.x.maxerror 0.00012700
will cause issues, this is supposed to be:
setp pid.x.maxerror 0.012700
Last edit: 2 years 5 months ago by PCW.
The following user(s) said Thank You: tovarna
  • tovarna
  • Topic Author
  • New Member
  • New Member
2 years 5 months ago #299946 by tovarna
Thanks.
Some more info
Yes, I might have named them the other way around. Will fix that maxerror too
2 years 5 months ago - 2 years 5 months ago #299950 by PCW
Note that if you use encoder feedback. the P term must be _much_ lower
(than 1000) or you will have oscillations.
Time to create page: 0.064 seconds
