mesa_modbus vs Omron Q2A VFD struggling
- pingtomi
24 May 2024 16:12 - 24 May 2024 16:13 #301358
by pingtomi
mesa_modbus vs Omron Q2A VFD struggling was created by pingtomi
Dear All,
I've set up Mea 7i95 + mesa_modbus with Omron Q2A VFD. Wiring is OK, communication works at physical layer, but I'm in stuck, because:
Omron Q2A VFD expects the following Modbus commands:
CW run: Func code: 0x10, address 0x0001, value 1 (last bit)
CCW run: Func code: 0x10, addres 0x0001, value 2 (last two bit)
STOP: Func code: 0x10, addres 0x0001, value 0
Freq: Func code 0x10, address 0x0044
But spindle.0.forward and spindle.0.reverse are binary outputs, how can I link them to Modbus?
I mean modbus would write "1" when spindle.forwad=true, and "2" when spindle.reverse=true at address 0x0001
This was easy with vfd_modbus, but how to do with mesa_modbus? I couldn't figure it out.
+ cw and ccw and stop register address is the same. It seems it is not supported if I link two hal_pins to the same address in mesa_modbus conf file.
+ func code 0x10 is not supported ... ? btw it seems it works with 0x06, however based on the official manual 0x10 is expected.
Would be great to get rid of vfd_modbus due to lack of rs485 ports in my new industrial PC.
Thank you for your ideas!
Tamas
Tamas
Last edit: 24 May 2024 16:13 by pingtomi.
- Thank you received: 5336
24 May 2024 19:51 #301364
Replied by PCW on topic mesa_modbus vs Omron Q2A VFD struggling
You can use the weighted_sum component
to combine individual bits to create an integer
command
command
25 May 2024 05:33 #301399
Replied by andypugh on topic mesa_modbus vs Omron Q2A VFD struggling
I wrote the enum component for this specific application.
linuxcnc.org/docs/stable/html/man/man9/enum.9.html
25 May 2024 05:39 #301400
Reading through my own docs, I think you probably want
D;;forward;reverse
To create forward and reverse pins that output a 1 or a 2.
D;;forward;reverse
- pingtomi
26 May 2024 10:53 #301491
by pingtomi
Replied by pingtomi on topic mesa_modbus vs Omron Q2A VFD struggling
Thank you, but it seems Q2A does not accept Modbus function code 0x06, I always get modbus error 134.
Is there possible somehow to send 0x10 function code?
Thank you.
Thank you.
26 May 2024 11:30 #301496
Yes, it should just be a case of changing the line in the config file. Probably to
(HAL_U32, 16, 0x001, 1, "OnOffDirection") Please Log in or Create an account to join the conversation.
- pingtomi
26 May 2024 11:53 - 26 May 2024 12:00 #301502
by pingtomi
So I tried vfd_mod (github.com/aekhv/vfdmod) and Q2A works with func code 0x06, debug output:
vfdmod: setting command speed value to 500 (0x01F4)...
[01][06][00][02][01][F4][28][1D]
Waiting for a confirmation...
<01><06><00><02><01><F4><28><1D>
My mesa_modbus setup as follows:
7i95 with pktUart support:
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 192.168.1.121: INFO: Hardware address (MAC): 00:60:1b:15:01:17
hm2_eth: discovered 7I95
hm2/hm2_7i95.0: Low Level init 0.15
hm2/hm2_7i95.0: created PktUART Interface function hm2_7i95.0.pktuart.0.
hm2/hm2_7i95.0: Smart Serial Firmware Version 43
hm2/hm2_7i95.0: IO Pin 015 (TB4-20/TB4-21): PktUART Receive Channel #0, pin RX Data (Input)
hm2/hm2_7i95.0: IO Pin 016 (TB4-22/TB4-23): PktUART Transmit Channel #0, pin TX Data (Output)
hm2/hm2_7i95.0: IO Pin 017 (TB4-22/TB4-23): PktUART Transmit Channel #0, pin Drv Enable (Output)
wired Rx+(tb4/20) to Tx+(tb4/22), 560R to GND
wired Rx-(tb4/21) to Tx-(tb4/23), 560R to +5V
connected to Q2A
Q2A detects the Modbus connection when Linuxcnc starts, "CALL serial connection error" disappears
vfd.mod:
#define MAX_MSG_LEN 32 // may be increased if necessary to max 251
//#define DEBUG
static const hm2_modbus_chan_descriptor_t channels = {
/* {TYPE, FUNC, ADDR, COUNT, pin_name} */
{HAL_FLOAT, 6, 0x0001, 1, "spindle_control"},
{HAL_FLOAT, 6, 0x0044, 1, "spindle_freq"},
HAL:
loadrt vfd ports=hm2_7i95.0.pktuart.0
addf vfd.00 servo-thread
setp vfd.00.address 0x01
setp vfd.00.baudrate 9600
setp vfd.00.txdelay 20
setp vfd.00.parity 2
setp vfd.00.update-hz 2
I see spindle_control and spindle_freq pins in halshow, but I can't "do anything" by sending some values manually.
If I change HAL_FLOAT type to HAL_S32 or HAL_U32 I always get "DnE drive disabled comm error" message on Q2A, return code 128 and have to reset the drive.
Otherwise I always get error 134.
Any clue please?
Thx a lot!
Tamas
connected to Q2A
vfd.mod:
//#define DEBUG
HAL:
Any clue please?
Thx a lot!
Tamas
Last edit: 26 May 2024 12:00 by pingtomi.
- pingtomi
26 May 2024 14:41 #301513
by pingtomi
Is there a way somehow to debug/display modbus messages which are sent out?
Time to create page: 0.164 seconds
