Joypad Joint and Cartesian Mode Jogging
  • Project_Hopeless
  • Project_Hopeless's Avatar Topic Author
  • Elite Member
  • Elite Member
26 May 2024 20:42 #301540 by Project_Hopeless
Joypad Joint and Cartesian Mode Jogging was created by Project_Hopeless
I have a 5-DOF robot.  I have my Joypad setup so that in World/Cartesian, the left joystick is X and Y, the right Z.  I have the directions relative a 1st person POV.  This works as I intended.
When I switch to joint mode in Axis The individual axis that jogs is not natural and I would like to change that for joint mode jogging.
Is there a way to make the "input." assignments from the joypad conditional, one assignment set for World, another for Joint mode?
28 May 2024 05:35 #301654 by andypugh
Replied by andypugh on topic Joypad Joint and Cartesian Mode Jogging
Yes. Look in your HAL file and you probably have a block of assignments like:
net jog-x input.0.analog0 axis.x.jog-analog joint.0.jog-analog
(This is from memory, but something like that)
You just need to swap the joint letters and axis numbers to suit your requirements.
  • Project_Hopeless
  • Elite Member
  • Elite Member
28 May 2024 19:17 - 28 May 2024 19:19 #301710 by Project_Hopeless
Replied by Project_Hopeless on topic Joypad Joint and Cartesian Mode Jogging
andypugh post=301654 userid=723
Andy,  That would make it a permanent change no?
I'm looking to be able to toggle the joypad behavior based on the current jog mode mode World/Joint.  Is that possible, a sort of "IF" statement  in HAL?
Last edit: 28 May 2024 19:19 by Project_Hopeless.
29 May 2024 01:01 #301730 by Aciera
Replied by Aciera on topic Joypad Joint and Cartesian Mode Jogging
For switchkins (which you are probably using) you could connect your respective jogging input pins to 'kinstype.is-0' / 'kinstype.is-1' by means of an 'and2' component.
The following user(s) said Thank You: Project_Hopeless
Time to create page: 0.075 seconds
