Vista CNC and 2.9
- Thank you received: 2177
31 May 2024 14:26 - 31 May 2024 14:28 #301984
Replied by Aciera on topic Vista CNC and 2.9
Apologies, I was trying to show how signals are different from pins.
Try this:
# 12---SPINDLE
net spindle-start <= vc-p4s.spindle.start => halui.spindle.0.start
net spindle-stop <= vc-p4s.spindle.stop => halui.spindle.0.stop
net spindle-is-on <= halui.spindle.0.is-on => vc-p4s.spindle.is-on => parport.0.pin-01-out
Try this:
# 12---SPINDLE
Last edit: 31 May 2024 14:28 by Aciera. Reason: Change signal names to make them look less like pins
- milu
31 May 2024 16:56 #302010
by milu
Replied by milu on topic Vista CNC and 2.9
I replaced my section 12 with the code you suggest and linuxcnc aborts with:
./vc-p4s.hal:109: Pin 'parport.0.pin-01-out' was already linked to signal 'spindle-on'
So I commented this line out in the main hal:
#net spindle-on => parport.0.pin-01-out
and that fixes the error, but the spindle still does not operate.
Can I ask a basic question? If this section of src/emc/motion/command.c is reached (which it is) shouldn't the spindle turn on?
case EMCMOT_SPINDLE_ON:
rtapi_print_msg(RTAPI_MSG_DBG, "SPINDLE_ON: spindle %d/%d speed %d\n",
emcmotCommand->spindle, emcmotConfig->numSpindles, (int) emcmotCommand->vel);
spindle_num = emcmotCommand->spindle;
if (spindle_num >= emcmotConfig->numSpindles){
reportError(_("Attempt to start non-existent spindle"));
emcmotStatus->commandStatus = EMCMOT_COMMAND_INVALID_COMMAND;
break;
break;
31 May 2024 23:03 #302036
I'm not sure that looking at the source code is the most efficient way of getting your spindle to turn. In your current situation it would be more straightforward to figure out how the hal language works because that is where the relevant connections are made to get signals to your parallel port. So I would strongly suggest to focus on your hal signal paths using the 'show hal configuration' tool.
My most immediate question would be:
What is the state of 'parport.0.pin-01-out'.
If that goes true and your spindle does not turn then your problem is likely in the wiring. If it does not go true then you would want to find out why by looking at 'halui.spindle.0.is-on'.
Time to create page: 0.677 seconds
