Using linuxcnc to drive a delta robot arm in real time
03 Jun 2024 17:02 #302251 by hellvetica
I'm fairly new to linuxcnc and am working with a colleague who is relatively experienced. We made a large delta robot arm and plan to use it as a pick and place system coupled with a vision system to move items from a conveyor belt. We setup the arm in linuxcnc and can move it using gcode. The motion control and IK work fine.
I managed to use the python MDI interface to send gcode to the arm. This works OK but there is a small delay when sending the commands and I don't know how I would approach timing and synchronizing the movements through gcode as you don't really know when exactly they're going to be executed.
Ideally, I would somehow inject my coordinates and speeds into the motion controller using HAL but after digging quite a bit I didn't find an obvious way to do that.
What is the best way to do this and how would you approach this?
04 Jun 2024 05:51 #302295 by Aciera
For timing critical applications you would probably want to avoid anything python and use C/C++ instead.
I would try to use a C HAL component to get the required values into hal, then use the motion.digital and motion.analog pins and use M66 to wait for the respective values in a running gcode.
The following user(s) said Thank You: tommylight, DPFlex, hellvetica
