How to Turn One Output Signal Into Many
31 Jul 2024 11:09 - 31 Jul 2024 11:10 #306541 by bkt
Replied by bkt on topic How to Turn One Output Signal Into Many
for these pourpouse (one impot to multiple output) in 2014 i write a simple component .... think shared here pehaps ... but after really see Andy insert a new one for the same in Comp list of linuxcnc .... any how actually prefer to use logicladder ... more easy and efficent ..... yea block is short .... if is for a special pourpose you need write a new user comp .... at least is easy for these. .... if(x=1){.......} elseif(x=2){.....} etc etc ..... pherhaps compgenerator now it work well? into 2.7 and 2.8 not so ....
Last edit: 31 Jul 2024 11:10 by bkt.
The following user(s) said Thank You: my1987toyota
  • Moderator
  • Moderator
31 Jul 2024 11:10 #306542 by tommylight
Replied by tommylight on topic How to Turn One Output Signal Into Many
Second post here, configs attached, and so are STL so skip them
forum.linuxcnc.org/show-your-stuff/46752...ver-etcher-scratcher
  • my1987toyota
  • my1987toyota's Avatar Topic Author
  • Platinum Member
  • Platinum Member
31 Jul 2024 11:27 - 31 Jul 2024 11:35 #306544 by my1987toyota
Replied by my1987toyota on topic How to Turn One Output Signal Into Many
WOW, so many responses. I look away for a few minutes and already the topic is on pg.2. LOL
anyway. Aciera the reason I don't have the error message posted is because that happend days ago
and I found a work around for that instance. I posted this topics question so I know for future reference if
it happens again how best to deal with it. The way I handled it worked this time, but may not on
what ever machine I would be building in the future. I don't mean to have people frustrated trying to figure
out what I am trying to do but at the time of the problem I didn't think about saving the error report I
just tried something else and that worked. I will try to be more diligent next time.
tommylight when I get a chance this evening (my time anyway) I will give that a good look over.Thanks.  And yes
this because of the Foam cutter. I am just trying to find better ways of doing things.LOL
Last edit: 31 Jul 2024 11:35 by my1987toyota. Reason: adding response
Time to create page: 0.133 seconds
