Add Axis
- RLA
- Thank you received: 3
23 Aug 2024 13:51 - 23 Aug 2024 14:09 #308491
by RLA
Add Axis was created by RLA
hi...new user here...trying to add an axis..copied/pasted /edited...still something not right....not sure what I am doing wrong..
Thanks for any help
Rick
Sorry....just found the error...missed one b reference...Thanks!!!
Thanks for any help
Rick
Last edit: 23 Aug 2024 14:09 by RLA.
- Thank you received: 7504
23 Aug 2024 16:39 #308498
Replied by tommylight on topic Add Axis
You are getting the hang of it pretty good, so not "new user" anymore !
The following user(s) said Thank You: RLA
- RLA
26 Aug 2024 12:16 #308720
by RLA
Replied by RLA on topic Add Axis
Hi...I copied a working axis as far as being able to jog with no error...but when I jog new axis (U)...I get Joint follow error...not sure what I am doing wrong...I tried to switch pins to another working axis and still had problem with U...other axis still worked after switch pin...??
- Thank you received: 5336
26 Aug 2024 12:51 #308721
Replied by PCW on topic Add Axis
One way to debug this is to widen the following error limits
and then plot the commanded and feedback joint positions
with halscope.
with halscope.
- RLA
26 Aug 2024 15:16 #308736
by RLA
So I am new to lcnc...will have to learn halscope...in the meantime out of curiosity...what is the actual feedback looked for that results in error when not found?...
Thanks!
Thanks!
26 Aug 2024 15:26 #308739
net u-pos-cmd <= joint.4.motor-pos-cmd
net u-pos-fb <= hm2_7i96s.0.stepgen.07.position-fb
- RLA
26 Aug 2024 16:36 #308743
by RLA
I left shop for today but just noticed this in my hal...no reference to new axis (U)...would that cause the error?...thanks!addf hm2_7i96s.0.read servo-thread
addf pid.x.do-pid-calcs servo-thread
addf pid.y.do-pid-calcs servo-thread
addf pid.z.do-pid-calcs servo-thread
addf pid.a.do-pid-calcs servo-thread
addf pid.s.do-pid-calcs servo-thread
addf hm2_7i96s.0.write servo-thread
setp hm2_7i96s.0.dpll.01.timer-us -50
setp hm2_7i96s.0.stepgen.timer-number 1
# external output signals
26 Aug 2024 17:28 #308744
Yes, you are missing the:
addf pid.u.do-pid-calcs servo-thread
so the "U" PID pins are there but they are not functioning
- RLA
26 Aug 2024 17:48 #308745
by RLA
What a relief!! So in terms of unreliable hardware...its me!!
Thanks again..glad to be able to move on...
Thanks again!
Thanks again!
Time to create page: 1.029 seconds
