Calling and halui mdi command generates mode error
2 years 1 month ago #310672 by RyanB
Hi, I am trying to change mess around with my machines .hal file so when an M6 tool change request is generated it runs and MDI command. Every time I run it though I get the error "Can't switch mode while mode is AUTO and interpreter is not IDLE"
The net change I am making in hal is from
net tool-change-request    =>  hal_manualtoolchange.change
to
net tool-change-request    =>  halui.mdi-command-00
The MDI command in the INI is
[HALUI] MDI_COMMAND = G90 G00 Z10
My testing ngc file is
% G90 T2 M6 %
I've tried to keep things as simple as possible, but no matter what I try I keep getting this error. Could someone point me towards a solution?
2 years 1 month ago #310675 by Benb
According to the manual When a halui MDI pin is set (pulsed) true, halui will send the MDI command defined in the INI. This will not always succeed depending on the current operating mode (e.g., while in AUTO halui can’t successfully send MDI commands).
reference:
linuxcnc.org/docs/stable/html/gui/halui.html#_mdi_2
2 years 1 month ago #310687 by Aciera
It's not possible to call a [HALUI] MDI_COMMAND from Gcode. If you need to modify M6 then you would need to use a remap instead:
linuxcnc.org/docs/devel/html/remap/remap...g_the_m6_replacement
Time to create page: 0.045 seconds
