setting mpg scale with rotary switch
2 years 1 month ago #310724 by Krulli_Fräser
Hey all,
I am about done configuring my milling machine. One of the last things I need to do is set the mpg scales for my 3 handwheels.
All of these handwheels use encoders with different pulse/rev so I always need to assign a different scale to each axis. I want to have 3 speed settings and have already connected a 3 position rotary switch to select these settings. The three input pins for that are working fine.
I tried setting the values with a variable assignment in classicladder but can't seem to get it to output a float value.
All of the scale values I want to set are float values.
Does anyone know a solution for this?
2 years 1 month ago #310727 by PCW
Typically this would be done with a mux component.
If you have 3 inputs, you could use a mux8 component
If the 3 inputs are binary coded, you get 8 separate scales.
If the 3 inputs are linear select (just one input active at a time),
you only get  3 selections but mux8 will still work.
2 years 1 month ago #310728 by Krulli_Fräser
Ok I see.
I have three seperate inputs from the selector switch that are exclusive to each other (only one active at a time).
I would need 3 mux components, one for each axis for my different values right?
2 years 1 month ago - 2 years 1 month ago #310731 by PCW
edit2:
 Since you only have 3 options for jog increments you only need
one mux8 component. (any individual MPG PPR related scaling would
be done by a fixed factor elsewhere)
Think of mux8 as a 1/8 selector switch with 8 inputs and one
output and a 3 bit binary code that selects the switch position.
Last edit: 2 years 1 month ago by PCW.
The following user(s) said Thank You: Krulli_Fräser
2 years 1 month ago #310732 by Krulli_Fräser
I can only see one output value per selection is possible.
I need these values:
Fast setting: x-scale: 0.00125 y-scale: 0.003125 z-scale: 0.0005
Medium setting: x-scale: 0.00025 y-scale: 0.000625 z-scale: 0.0001
Slow setting: x-scale: 0.00005 y-scale: 0.000125 z-scale: 0.00002
I need these different settings because each axis has a different encoder and because i always want the z axis to move less per turn.
2 years 1 month ago - 2 years 1 month ago #310736 by PCW
You would typically scale the encoders with a fixed number
with  the encoder scale setting parameter.
Then all the jog increment values for the mux would be the same
for all axis
Time to create page: 0.318 seconds
