- Thank you received: 7491
Those can be "mom" and "dad", it does not matter, they are signal names that you freely assign to connections between hal pinsTrying to understand why "generic-1" and "generic-2" are necessary.
Thank-you for taking the time to draw it out. Its' more clear now!Benb post=311153 userid=20877It looks like you having problem distinguishing hal pin names from hal signal names. It's a common mistake by new linuxcnc hal users. further to Tom's explanation, I draw a block diagram, The dashed lines are your signal names generic-1 on the left and generic-2 on the right. If you connect them together you short circuit the input and output of the toggle component.
