- Thank you received: 10
That worked like a charm!Maybe this can be done with one momentary button, toggle component and mux2, toggle between 2 float values. You can setp mux2.N.in0 and mux2.N.in1 to the desired float value and control it with toggle.N.out to mux2.N.sel
