calling python file
31 Oct 2024 10:46 #313538 by Abdulkareem
calling python file was created by Abdulkareem
i have a python script that runs automatically when i start linuxcnc, i want to make a button in the ui that runs the script when i click on it. i use this code to run it (loadusr python3 /home/abdulkareem/linuxcnc/configs/Ethercat_FInal/import_logging.py) in the postgui file iam using axis ui.
31 Oct 2024 11:04 #313539 by Aciera
Replied by Aciera on topic calling python file
- Use the same procedure you used to create the custom Mcode for the python scirpt here:
forum.linuxcnc.org/20-g-code/54265-calling-python-file#313421
- Create a new HAL_COMMAND entry in the [HALUI] section of your ini file (change M code number to the one you are using):
MDI_COMMAND = M199
- Make sure the [HAL] section of your ini file contains this entry:
HALUI = halui
Then connect your GUI button to the MDI_COMMAND in your hal file:
net call_script => halui.mdi-command-00 <= <your_vcp_button_pin_here>
Time to create page: 0.569 seconds
