CAROUSEL ATC
27 Nov 2024 03:31 #315349 by Abdulkareem
CAROUSEL ATC was created by Abdulkareem
hello guys
i am trying to implement the CARSOUSEL for my ATC , i am using ethercat stepper motor for the carsousel and i found there are multiple types of encoding which actual i dont understand the difference between them. i have 10 pockets and if there is an simillar configuration to mine that i could understand from it would be perfect!
  • Moderator
  • Moderator
27 Nov 2024 05:15 #315356 by tommylight
Replied by tommylight on topic CAROUSEL ATC
How many sensors does your ATC have?
What do they do?
27 Nov 2024 05:19 #315357 by Abdulkareem
Replied by Abdulkareem on topic CAROUSEL ATC
actually i dont have any sensors except tool length sensor , i am using servo motors with absolute encoders
  • Moderator
  • Moderator
27 Nov 2024 05:36 #315362 by tommylight
ATC must have some sensors, be it index and pocket, or gray scale, or binary, or ....
28 Nov 2024 03:18 - 28 Nov 2024 04:02 #315443 by Abdulkareem
yes i know that if i want to ue this component i will need sensors but what is the difference between them
Last edit: 28 Nov 2024 04:02 by Abdulkareem.
  • Moderator
  • Moderator
28 Nov 2024 07:18 #315463 by tommylight
It this a DIY ?
28 Nov 2024 08:14 #315469 by Abdulkareem
yes
  • Moderator
  • Moderator
28 Nov 2024 08:38 #315471 by tommylight
Pictures?
Time to create page: 3.632 seconds
