Error problem hm2 7i96s 7i77 analogout scalemax not found ?
- programador
- Thank you received: 5
14 Jan 2025 08:54 #318947
by programador
Error problem hm2 7i96s 7i77 analogout scalemax not found ? was created by programador
Hello everyone, I'm back, happy 2025 to all. Please, I need help to return to the retrofit process of a punching machine.
I have the hardware configuration 7i96s + 7i77 + 7i84d and THCAD2
I need to make the 7i77 board work to drive the Z axis with feedback from the THCAD2. To get a basic code example, I used linuxCNC's PNCConf to generate a basic code example.
The basic code generated was:
# ---PWM Generator signals/setup---
setp hm2_7i96s.0.7i77.0.0.analogout0-scalemax [JOINT_1]OUTPUT_SCALE
setp hm2_7i96s.0.7i77.0.0.analogout0-minlim [JOINT_1]OUTPUT_MIN_LIMIT
setp hm2_7i96s.0.7i77.0.0.analogout0-maxlim [JOINT_1]OUTPUT_MAX_LIMIT
net z-output => hm2_7i96s.0.7i77.0.0.analogout0
net z-pos-cmd <= joint.1.motor-pos-cmd
net z-enable <= joint.1.amp-enable-out
setp hm2_7i96s.0.encoder.00.counter-mode 0
setp hm2_7i96s.0.encoder.00.filter 1
setp hm2_7i96s.0.encoder.00.index-invert 0
setp hm2_7i96s.0.encoder.00.index-mask 0
setp hm2_7i96s.0.encoder.00.index-mask-invert 0
setp hm2_7i96s.0.encoder.00.scale [JOINT_1]ENCODER_SCALE
net z-pos-fb <= hm2_7i96s.0.encoder.00.position
net z-vel-fb <= hm2_7i96s.0.encoder.00.velocity
net z-pos-fb => joint.1.motor-pos-fb
net z-index-enable joint.1.index-enable <=> hm2_7i96s.0.encoder.00.index-enable
net z-pos-rawcounts <= hm2_7i96s.0.encoder.00.rawcounts
# ---setup home / limit switch signals---
net z-home-sw => joint.1.home-sw-in
net z-neg-limit => joint.1.neg-lim-sw-in
net z-pos-limit => joint.1.pos-lim-sw-in
But when trying to apply this example the error appears:
hm2_7i96s.0.7i77.0.0.analogout0-scalemax not found
The board The 7i77 electronics have all the necessary voltages, all the yellow LEDs are on and the green one too.
I have already managed to control the output and input through the classicladder, but unfortunately I am not having success in controlling the Z axis.
The HAL configuration is
loadrt hm2_eth board_ip="10.10.10.10" config="num_encoders=8 num_pwmgens=1 num_stepgens=5 sserial_port_0=3000"
Note: the number 3 in sserial_port_0 was necessary to recognize the 7i84d
How do I solve the error problem: hm2_7i96s.0.7i77.0.0.analogout0-scalemax not found?
I appreciate any suggestions or basic examples for configuring the 7i77
- Thank you received: 5336
14 Jan 2025 09:19 #318951
Replied by PCW on topic Error problem hm2 7i96s 7i77 analogout scalemax not found ?
Has the 7I96S been programmed with 7i96s_7i77d.bin firmware?
- programador
14 Jan 2025 10:44 #318960
by programador
Replied by programador on topic Error problem hm2 7i96s 7i77 analogout scalemax not found ?
Yes, the 7i96s board has been updated, attached readhmid and bin files.
14 Jan 2025 10:58 #318962
Look, like you have the channel number wrong for the analog 7I77 section
(its channel 1 not 0)
The following user(s) said Thank You: programador
- programador
14 Jan 2025 11:00 #318963
by programador
This error appeared when I took the data generated by PNCConf to try to include part of it in the programming code of the machine that I am already developing. But while I was waiting for your answer, I had the idea of creating a new file through the basic PNCConf and gradually including the code of the machine under development. In this code, it is accepting the "analogout scalemax". I will leave it attached in case anyone needs a basic initial code for 7i96s with 7i77. I will try this method. Thank you for your attention, Mr. PCW.
14 Jan 2025 11:02 #318965
Note, you can get a better idea of sserial channel --> 7I77 assignments with:
mesaflash --device 7i96s --addr 10.10.10.10 --dbname3 7i77 --readhmid
- programador
14 Jan 2025 12:13 #318971
by programador
Thanks for the suggestion of the command below:
It's a great option to debug any problems. But unfortunately in my case it wasn't allowed, the error below appeared:
lbp16_access.send_packet: Operation not permitted
Aborted
Do I have to assign a name or register it in the system so that readhmid works through the name? If so, do you have an example?
Aborted
14 Jan 2025 12:30 #318972
You cannot run that command when LinuxCNC is running
or when it exited on a major error, because linuxCNC
blocks access to the Ethernet port it is using when it is running.
LinuxCNC restores access when it exits normally
The following user(s) said Thank You: besriworld, programador
Time to create page: 0.196 seconds
