estop issue
- jyeomans
22 Feb 2025 09:24 #322274
by jyeomans
estop issue was created by jyeomans
i am not sure whether this is a hal issue or an issue with qtdragon_hd.
i have just installed 2.9 the newest build,
and rebuilt my machine. on my old machine the esop on the screen and the physical estop worked independantly.
now the estop on the screen only reflects the physical button. may be this is the way it is ment to work and i just had somthing different.
i liked it as i get the button on the oppiset side form the screen and i had an estop on both sides of the machine.
# --- ESTOP-EXT ---
net estop-ext <= hm2_7i76e.0.7i76.0.0.input-11
# ---estop signals---
net estop-ext => iocontrol.0.emc-enable-in
- Thank you received: 7504
22 Feb 2025 10:53 #322278
Replied by tommylight on topic estop issue
That should be the proper way, it should not be possible to enable the machine on screen while any of the e-stop buttons are pressed.
- Thank you received: 4154
22 Feb 2025 13:12 #322293
Replied by rodw on topic estop issue
What GUI? some do funky stuff.
- jyeomans
22 Feb 2025 13:53 #322298
by jyeomans
Replied by jyeomans on topic estop issue
i am usine qtdragon_hd.
on my old setup
the michine will not run if the physical button is pressed.
but i coluld pres the software estop to kill the michine.
in the new build i can not press the software button. it is only a reflection of the physical button.
on my old setup
22 Feb 2025 18:05 #322323
You should use estop-latch
There is an example in hal examples on the forum
and this video
and this video
22 Feb 2025 18:29 #322325
Yes, there are instances when it is very useful, but not on simple/hobby/small machines, and especially not for beginners.
Why?You should use estop-latch
22 Feb 2025 18:40 #322328
Both of those versions can be correct.
on my old setup
23 Feb 2025 01:36 #322342
QT dragon works well with my setup (as does Axis) I don't use estop_latch with it.
The video (not mine) explains why. My last couple of machines I used a safety relay so estop is external and I utilised an external reset button but I did test and consider using user_request_enable. You should not depend on a software estop if you have ired one in anyway.
Why?
