command for see value pin
- papagno-source
- Thank you received: 13
28 Mar 2025 15:04 #325186
by papagno-source
command for see value pin was created by papagno-source
Hi i want know if existe a command in terminal for read the value the hal pin, not in cyclic mode, but read value only at start the hal command interminal.
- Thank you received: 2181
29 Mar 2025 00:14 #325226
Replied by cmorley on topic command for see value pin
In a terminal enter:
halcmd show pin <PIN NAME>
Time to create page: 0.124 seconds
