Running an external program from a HAL pin
11 Apr 2025 16:51 - 11 Apr 2025 16:58 #326122 by PCW
Another possibility would be a script with halcmd  in a loop,
watching the desired pin/signal  (halcmd -s show pin spindle.0.on | grep TRUE)
(this could also turn off the spindle if LinuxCNC was not running)
Last edit: 11 Apr 2025 16:58 by PCW.
11 Apr 2025 17:12 #326123 by Grotius
Replied by Grotius on topic Running an external program from a HAL pin
@Pcw,
Yes, that should work.
Script below works.
$ halcmd -s show pin halui.estop.is-activated
prints:
halui bit   OUT FALSE halui.estop.is-activated
Then get the FALSE or TRUE in a script:
Warning: Spoiler!
12 Apr 2025 09:23 #326167 by pgf
I spent my career trying to write reasonably efficient and fast code in firmware, device drivers and system level utilities. I'm afraid I just couldn't stomach adding a polling loop on top of the polling loop (every .2 seconds) that I discovered at the core of halui.
So I've done an end-run around the problem, which works nicely.
My mill runs from a Raspberry Pi, connected via a Mesa ethernet card. It occurred to me that if HAL could twiddle an actual gpio pin, then I could easily read that, and hook it up to action.  And of course if there's one thing the RPi has, it's plenty of gpio.
So I loaded hal_gpio, and hooked up a couple of output pins:
loadrt hal_gpio outputs=GPIO16,GPIO20
addf hal_gpio.write servo-thread
net external-estop-off \
        estop-latch.0.fault-out => hal_gpio.GPIO16-out
net coolant-mist => hal_gpio.GPIO20-out
Those pins were chosen because they were eacy immediately adjacent to another unused pin.  Gpio 16 is next to 19, and 20 is next to 26.  I jumpered those two pairs.
Then I wrote a short script using gpiomon to watch pins 19 and 26 for transitions.
#!/bin/bash
estop=19
vacuum=26
switch()
    echo Turning $1 $2   # e.g. "Turning vacuum on"
    wget -q -O /dev/null http://service:9901/event:cnc-mill-$1-$2 &
while read pinevent
do
    echo got $pinevent   # this will be "19-1", "19-0", "26-1", or "26-0"
    case $pinevent in
    $estop-1)
        switch spindle off
    $vacuum-0)
        switch vacuum off
    $vacuum-1)
        switch vacuum on
    esac
done < <( gpiomon  --line-buffered --format="%o-%e" gpiochip0 19 26)
This works perfectly.
While I'm pleased to have found this solution, it sure seems silly to have had to consume 4 gpio pins in order to do it.
Thanks for all your suggestions!
paul
Time to create page: 0.288 seconds
