GMOCCAPY - Cannot find pin error
18 Apr 2025 04:06 #326577 by andrei_linuxcnc
GMOCCAPY - Cannot find pin error was created by andrei_linuxcnc
Hi, I'm new to LinuxCNC and I really need your help on this issue I run into.I created a custom button in Glade.
So I made a Top Level window named window1, put in a HAL table, hal_table1 and inside the HAL table a HAL button, hal_button1. I save the file as test.glade.
I'm using Glade 3.8.6 on LinuxCNC 2.8.4.
I added to the .ini file the following lines:
- In AXIS:GLADEVCP = -u hitcounter.py test.glade
POSTGUI_HALFILE = andrei.hal
In andrei.hal I have: setp gladevcp.hal_table1 TRUE
The button is show on the interface and it's active. This is working perfect.Now I want to implement the same in gmoccapy
-In GMOCCAPY:
EMBED_TAB_NAME = test
EMBED_TAB_COMMAND = gladevcp -c gladevcp -x {XID} test.glade
EMBED_TAB_LOCATION = box_custom_2
If I comment the setp gladevcp.hal_table1 TRUE in andrei.hal, the button is shown in the interface, but it is greyed out.
When I uncomment the line in andrei.hal the LinuxCNC is not starting and I have the error:andrei.hal:1: parameter or pin 'gladevcp.hal_table1' not found. Please see the linuxcnc.txt error report.
If I comment the line in andrei.hal and start the LinuxCNC with Gmoccapy interface, the button is greyed but I see the gladevcp.hal_table1 pin and I can send in halshow the setp gladevcp.hal_table1 TRUE command and it's working fine.
Also after loading the interface, I can see pins with halcmd show pin | grep hal_table1.
So as far as I can understand, the gladevcp.hal_table1 pin is not available at runtime in gmoccapy.
I tried a lot of settings with these commands and configurations and I don't know what I'm doing wrong, as aI follow the exact guidelines from the documentation.
I attach the .ini file. test.glade, andrei.hal files and the eror report linuxcnc.txt.
18 Apr 2025 04:13 #326578 by besriworld
Replied by besriworld on topic GMOCCAPY - Cannot find pin error
Check in hawshow if there is an enable pin for this window glade ...
If you have a different theme color, you can fix it by looking at the last comment on this post.
forum.linuxcnc.org/gmoccapy/45856-spindl...capy?start=40#313268
Time to create page: 0.586 seconds
