(SOLVED) hal_gpio: Operation not permitted fault cannot be solved
1 year 4 months ago - 1 year 4 months ago #330574 by bladekel
Hello to all.
I'm using Linuxcnc 2.9.4 on rpi5 debian bookworm that is installed from linuxcnc rpi5 image.
I have a problem on running my setup.
I tried many things like adding gpio to my user, creating a file 90-gpio-access that is mentioned on hal_gpio manual ( linuxcnc.org/docs/devel/html/drivers/hal_gpio.html )
but I failed.
Here is my fault information;
Print file information: RUN_IN_PLACE=no LINUXCNC_DIR= LINUXCNC_BIN_DIR=/usr/bin LINUXCNC_TCL_DIR=/usr/lib/tcltk/linuxcnc LINUXCNC_SCRIPT_DIR= LINUXCNC_RTLIB_DIR=/usr/lib/linuxcnc/modules LINUXCNC_CONFIG_DIR= LINUXCNC_LANG_DIR=/usr/lib/tcltk/linuxcnc/msgs INIVAR=inivar HALCMD=halcmd LINUXCNC_EMCSH=/usr/bin/wish8.6 LINUXCNC - 2.9.4 Machine configuration directory is '/home/cnc/linuxcnc/configs/my-mill' Machine configuration file is 'my-mill.ini' INIFILE=/home/cnc/linuxcnc/configs/my-mill/my-mill.ini VERSION=1.1 PARAMETER_FILE=linuxcnc.var TPMOD= HOMEMOD= TASK=milltask HALUI= DISPLAY=axis COORDINATES=X Y Z A KINEMATICS=trivkins coordinates=XYZA Starting LinuxCNC... Starting LinuxCNC server program: linuxcncsvr Loading Real Time OS, RTAPI, and HAL_LIB modules Starting LinuxCNC IO program: io linuxcnc TPMOD=tpmod HOMEMOD=homemod EMCMOT=motmod Found file(REL): ./my-mill.hal Shutting down and cleaning up LinuxCNC... Removing HAL_LIB, RTAPI, and Real Time OS modules Removing NML shared memory segments Debug file information: Note: Using POSIX realtime Failed to register output pin collection hal_gpio: rtapi_app_main: Operation not permitted (-1) ./my-mill.hal:4: waitpid failed /usr/bin/rtapi_app hal_gpio ./my-mill.hal:4: /usr/bin/rtapi_app exited without becoming ready ./my-mill.hal:4: insmod for hal_gpio failed, returned -1 2307 Stopping realtime threads Unloading hal components Note: Using POSIX realtime
my groups are;
cnc@raspberrypi:~$ groups cnc tty disk dialout sudo audio video plugdev users input render netdev i2c bluetooth gpio spi
Last edit: 1 year 4 months ago by bladekel.
1 year 4 months ago #330576 by unknown
The images are setup and no adding users to groups or messing around is needed.
Read the following thread and you'll find a link to GPIO info and a working example.
forum.linuxcnc.org/38-general-linuxcnc-q...official-images-only
The following user(s) said Thank You: bladekel
1 year 4 months ago #330577 by unknown
And unless you disable SPI you can not use the SPI pins for GPIO in linuxcnc
1 year 4 months ago - 1 year 4 months ago #330677 by bladekel
But I have tried both adding gpio to user and not adding. (They were with fresh image install)
I hav read all that link before writing here but nothing changed.
I am using hal and ini files from another working rpi5. Their user names, file names and locations are same.
If i added hal_gpio to hal file, it gives an error about permission.
I added gpio to user, not worked.
I have created 90-gpio-access file as it described, not worked....
The only thing that I havent tried is SPI... I will try it and write here...
1 year 4 months ago - 1 year 4 months ago #330682 by unknown
Failed to register output pin collection This has nothing to do with permissions. It has to do with the pins you have chosen. The error message did not mention permissions. A lot of issues are able to be resolved by users reading the errors messages and not jumping to conclusions. The thread also includes information regarding choosing pins that are allocated to SPI. Either you missed this or chose to ignore it. The example hal & ini files do work with a fresh install, I have tested these myself.
Last edit: 1 year 4 months ago by unknown.
1 year 4 months ago #330751 by bladekel
This is the problem that I could not see.
Thanks for everything.
In my configuration I have used GPIO7 and GPIO8 as I/O .
After disabling the spi, I solved the problem....
Time to create page: 0.479 seconds
