- LinuxCNC
- General LinuxCNC Questions
- Index to Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!!
- unknown
- Thank you received: 323
26 Mar 2025 17:07 - 23 Jun 2025 18:04 #325007
by unknown
Index to Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!! was created by unknown
Intro:
I'm trying to index some of the issues, solutions and info contained in the thread mention in the title. As I would like to keep this "clean", it would be great if any new issues,queries additional info be posted here: forum.linuxcnc.org/9-installing-linuxcnc...official-images-only
(yes I know Raspberry is spelt wrong)
Cheers
Rob
General Stuff
About the Images: forum.linuxcnc.org/9-installing-linuxcnc...-only?start=0#320270
Networking Topics
Installation of Network Manager: forum.linuxcnc.org/9-installing-linuxcnc...only?start=10#320949
Network Setup by behai: forum.linuxcnc.org/9-installing-linuxcnc...only?start=10#320967
Additional Comments by Rodw: forum.linuxcnc.org/9-installing-linuxcnc...only?start=10#320972
Ethercat Status: forum.linuxcnc.org/9-installing-linuxcnc...only?start=10#321684
Simple Mesa Setup without Network Manager by PCW: forum.linuxcnc.org/9-installing-linuxcnc...only?start=30#323321
wifi setup without Network Manager: forum.linuxcnc.org/9-installing-linuxcnc...only?start=40#323701
Locales:
Locales by behai: forum.linuxcnc.org/9-installing-linuxcnc...only?start=10#320959
GPIO
Note that the below may help with those stuggling with Byte2Bot boards.
Regarding GPIO drivers: forum.linuxcnc.org/9-installing-linuxcnc...-only?start=0#320852
Basic Mill Config: forum.linuxcnc.org/9-installing-linuxcnc...only?start=10#321296
Thread related to issues when SPI is enabled and the user wishes to use SPI GPIOS: forum.linuxcnc.org/24-hal-components/564...not-be-solved#330574
Video/b]
Skewed Video Issue & Solution by 109jb: forum.linuxcnc.org/9-installing-linuxcnc...only?start=30#322167
Swap - zswap
Initial issue & Solution: forum.linuxcnc.org/9-installing-linuxcnc...only?start=30#322251
UI Isuues:
GMOCCAPY locking up when idle by U2fletch: forum.linuxcnc.org/9-installing-linuxcnc...only?start=40#323825
Solution: forum.linuxcnc.org/9-installing-linuxcnc...only?start=50#324087
Notes: This was related to zswap.
Cheers
Rob
General Stuff
Networking Topics
Locales:
GPIO
Video/b]
Swap - zswap
UI Isuues:
Last edit: 23 Jun 2025 18:04 by unknown.
The following user(s) said Thank You: tommylight, rdtsc
- unknown
26 Mar 2025 17:38 #325009
by unknown
Replied by unknown on topic Index to Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!!
If we fix the berry bit will the links still be good or do they need modifying ?
Pinning it would be a good idea, was hoping you would ask
Locking just to keep it clean, I like it
Tommy
Tommy
- unknown
26 Mar 2025 17:39 - 07 May 2025 03:59 #325010
by unknown
Extra Wired Network config
forum.linuxcnc.org/9-installing-linuxcnc...only?start=80#327930
Last edit: 07 May 2025 03:59 by unknown.
- unknown
26 Mar 2025 17:41 - 10 Sep 2025 08:45 #325011
by unknown
NFS Mounts & Wifi On Boot
forum.linuxcnc.org/18-computer/57167-rpi...twork-file-share-nfs
Last edit: 10 Sep 2025 08:45 by unknown.
- Thank you received: 7505
26 Mar 2025 19:48 #325016
Replied by tommylight on topic Index to Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!!
Fixed tittles for both, links still work, pinning it and locking it now so if you can not post or edit do let me know on the other topic.
Thank you.
Thank you.
- LinuxCNC
Time to create page: 0.204 seconds
