Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!!
- unknown
- Thank you received: 323
06 May 2025 16:18 #327865
by unknown
Replied by unknown on topic Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!!
There was a user having an issue with gmoccapy locking up, but this issue was related to zram, which was discussed earlier in this thread.
I've had my RPi 5 sitting there with Axis open connected to a "cobbled together" 7i92 and after a week and a half have only dropped one packet.
When I get a chance I'll look into the ethernet setup. For some basic advice, do not have a gateway nor DNS server entry for the NIC that the mesa card is connected to, it generates unwanted traffic on that interface.
TBH I'm not up on the meaning of the LEDs on the card you are using.
It maybe worth checking the manual and searching the forum for that answer.
- Thank you received: 5326
06 May 2025 18:17 - 06 May 2025 18:19 #327876
Replied by PCW on topic Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!!
RPI5 with a 7i96, and after some time I get a solid red INIT light on the mesa card, and obviously at that point have to reset the card to continue.
If the init light turns on when LinuxCNC is running, (with any Mesa Ethernet FPGA card)
it means you have a watchdog fault, likely because communications have been lost
for longer than the watchdog timeout setting. This is likely due to a network latency issue.
No reset is needed, though LinuxCNC will have to be restarted.
Last edit: 06 May 2025 18:19 by PCW.
The following user(s) said Thank You: unknown
- unknown
07 May 2025 08:54 #327930
by unknown
Here's the Mesa interface snippet from /etc/network/interfaces, note no DNS nor Gateway as mentioned previously.
Sorry for the delay in answering.
# Ethernet Static for Mesa card at 10.10.10.10
# Computer at 10.10.10.100
auto eth0
allow-hotplug eth0
iface eth0 inet static
address 10.10.10.100
netmask 255.255.255.0
hardware-irq-coalesce-rx-usecs 0
- Thank you received: 4149
10 May 2025 20:50 #328180
Replied by rodw on topic Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!!
This is likely your problem. Replace with a Meanwell MDR-20-5 or similar.Good day,
Currently the Mesa is on a 5v3A wall plug
- mikereid0817
19 May 2025 03:40 #328723
by mikereid0817
Replied by mikereid0817 on topic Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!!
I have installed the PI5 image (25-01-27) and have gotten everything working EXCEPT the hal_gpio input pins. Outputs...done, inputs... no luck. I can read the input pins with GPIO from python... but not within linuxcnc.
Any ideas?
Any ideas?
- unknown
19 May 2025 07:48 #328727
by unknown
Read through this thread, there is an example in this very thread.
- unknown
19 May 2025 09:41 #328730
by unknown
There is also an index to this thread located here.
forum.linuxcnc.org/38-general-linuxcnc-q...official-images-only
- billykid
- Thank you received: 83
14 Jun 2025 09:28 #330271
by billykid
Replied by billykid on topic Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!!
hi, i installed linuxcnc raspberry5 4gb image on ssd and it starts normally but i am not able to connect to wifi. i followed the instructions, used menuconfig with my data and country=IT but nothing. maybe because in the ssid there are two spaces? "FRITZ.Box 7590 BX" i tried before asking... god knows how much i tried
- billykid
15 Jun 2025 07:12 #330296
by billykid
I installed network manager and both connections, 7i80 and internet are fine.
- unknown
15 Jun 2025 07:26 #330298
by unknown
That's the easiest way, I think I mentioned that earlier, I like Network Manager as I can turn the wifi off whilst running a job.
Time to create page: 0.209 seconds
