Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!!
- unknown
- Thank you received: 323
11 Mar 2025 19:42 - 11 Mar 2025 19:45 #323701
by unknown
Replied by unknown on topic Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!!
Wifi setup is by running
Be sure to edit to choose option 5 "Edit wpa_supplicant" with your country code, ssid & password.
To setup network for a mesa fpga Ethernet card, choose option 6 "Edit interface" and modify eth0 to match post above if you have jumpered the board for "FIXED FROM EEPROM"
If you have jumpered for "FIXED 192.168.1.121" replace 10.10.10.100 with 192.168.1.100.
If your home wifi network is on the 192.168.1 network, use the 10.10.10 network for your Mesa card, refer to you card's manual for jumpers to change.
After config reboot
To check the network type in a terminal
Taken from 7i92 Manual
A final note, there is no network notification applet for the desktop, so you will not get any notifications when the network connects, disconnects or reconnects.
sudo menu-configBe sure to edit to choose option 5 "Edit wpa_supplicant" with your country code, ssid & password.
After config reboot
ip aTaken from 7i92 Manual
IP ADDRESS SELECTION
The 7I92 has three options for selecting its IP address. These options are selected
by Jumpers W5 and W6.
W5 W6 IP ADDRESS
DOWN DOWN FIXED 192.168.1.121 (DEFAULT)
DOWN UP FIXED FROM EEPROM
UP DOWN BOOTP
UP UP INVALID
Note: that the initial EEPROM IP address is set to 10.10.10.10 at Mesa, but can be
changed to any address with the mesaflash utility.A final note, there is no network notification applet for the desktop, so you will not get any notifications when the network connects, disconnects or reconnects.
Last edit: 11 Mar 2025 19:45 by unknown.
- U2fletch
13 Mar 2025 12:36 #323825
by U2fletch
Replied by U2fletch on topic Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!!
I installed LinuxCNC onto a RPi 400 with a touchscreen and GMOCCAPY. It works very well, but something has changed on the system and it is now unstable. LinuxCNC, is locking up after periods of inactivity. Running a Mesa 7i96 board. Wonder if doing another clean install will fix it. Might have had a bad update along the way. Will let you know what I discover....
- unknown
13 Mar 2025 13:04 - 13 Mar 2025 13:15 #323829
by unknown
Ok the description is a little vague.
I don't think a clean install will "fix it". I don't think an update would have anything affect as the kernel,kernel modules and firmwares should not be touched during an update. In all honesty unless you are wanting to update Linuxcnc, there shouldn't be a need to do an update, most updates are just minor fixes that really don't affect the way Linuxcnc operates. The biggest "security threat" to cnc machine is someone getting physical access, and it would be the machine it self I would be the most worried about, blood gets everywhere, it's hard to clean and the injured party may want to blame you. I only will have wifi on when transferring files to the cnc machine, other than that I disconnect wifi.
I think you maybe experiencing an issue similar to what is discussed in this thread. Which it would is not Linuxcnc related, it's the ethernet port going to sleep/shutting down, tho it should be tx\rx ing packets more or less continuously. Yes I know it's a direct connection from the Pi to the Mesa card and the thread mentions switches a few times.
forums.raspberrypi.com/viewtopic.php?t=305820
It seems to be somewhat random to which boards are affected but I haven't noticed this on my RPi400.
Tho it might be an idea to check the power supply for the Pi & the mesa card. But if ti was the mesa card "dropping out" you would get notifications.
Last edit: 13 Mar 2025 13:15 by unknown.
- unknown
14 Mar 2025 07:00 #323891
by unknown
Dude please don't change the subject, it makes things hard. I check this thread regularly.
- elovalvo
- Thank you received: 127
14 Mar 2025 07:18 #323894
by elovalvo
I think it is useful to change the title from
"Linuxcnc & the Rpasberry Pi"
to that
"Linuxcnc & the Raspberry Pi"
Replied by elovalvo on topic Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!!
to that
The following user(s) said Thank You: unknown
- Thank you received: 7478
14 Mar 2025 13:29 #323921
Replied by tommylight on topic Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!!
Fixed title.
- U2fletch
15 Mar 2025 03:54 #323983
by U2fletch
Sorry, did not think it would affect the whole thread.
- U2fletch
15 Mar 2025 04:01 #323984
by U2fletch
I have a second Pi 400 on my Ham Radio station, so I switched the two keyboards and fired up LinuxCNC on the "new" board. I let it sit for awhile trying to duplicate what happens. Basically the display becomes unresponsive to anything. The cursor moves around, but I cannot select between pages on GMOCCAPY. However I can still jog the machine around using my pendant, so It is still communicating with the Mesa 7i96 board. Also I cannot ctrl-Esc the Pi to access the task switcher, so something is locking up.
- unknown
15 Mar 2025 04:18 #323985
by unknown
One thing you can try is logging in via ssh, before things lockup, and when they do see if anything untoward shows up in dmesg or any of the other log files.
Does it occur when just running one of the sims from the Linuxcnc menus.
Are you able to use a config that uses Axis, if so does this give the same problems.
Just to confirm your are using one of the images from the downloads page, without an extra packages installed, cos I'm not sure if ctrl-esc gets the task manager. On the RPi5.which is the same apart from the kernel support, it doesn't bring up a task manager.
Before the title was changed, it was mainly to do with the Linuxcnc images, not Linuxcnc on Raspberry Pi OS.
Tommy if you see this can you change the topic heading so it reflects this is support for the Official Linuxcnc Rpi Images, I didn't intend for it to support Linuxcnc on the Raspberry Pi OS. That should be dealt with elsewhere.
I'm pretty sure the original tile reflected that.
15 Mar 2025 13:10 #324000
Is this OK or any better idea?
Time to create page: 0.527 seconds
