Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!!
- unknown
- Thank you received: 325
23 Apr 2025 10:24 #326948
by unknown
Replied by unknown on topic Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!!
As the image is a custom one, only the kernel is built from RPi Sources.
This pretty clear, I would have thought.
Where as you were attempting to install headers from the Debian repo
The kernel should load the drivers without any user intervention.
The following user(s) said Thank You: fletch
- fletch
- Thank you received: 72
23 Apr 2025 10:36 #326950
by fletch
To one well versed in building distributions, yes, but not necessarily to one who has only used distributions! Not until now, anyway
I was but at that point, didn't realise the significance of the kernel being sourced from a different place to the base distribution.
It does now load on boot.
Thank you.
Replied by fletch on topic Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!!
Thank you.
- fletch
23 Apr 2025 14:35 - 23 Apr 2025 14:37 #326959
by fletch
Just for completeness and to save anyone having to mess around with compiling kernel modules, here is what looks like a fairly comprehensive (at least until 6.13) list of in-kernel USB WiFi devices: github.com/morrownr/USB-WiFi/blob/main/h...in-kernel_drivers.md
Discovered it a little late but I think only one has an RP-SMA connection.
Last edit: 23 Apr 2025 14:37 by fletch.
The following user(s) said Thank You: unknown
- unknown
23 Apr 2025 14:54 #326960
by unknown
Dunn why RPi doesn't add a connector for an external antenna.
- fletch
23 Apr 2025 14:58 #326961
by fletch
That would be lovely - the CM5 has one but then you need a carrier board and I don't know if the LinuxCNC image would run on the CM5/eMMC? With the right carrier board would be perfect though...
- ErwinCNC
27 Apr 2025 08:47 #327134
by ErwinCNC
Replied by ErwinCNC on topic Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!!
Hello
I put my pi 5 into operation yesterday.
Unfortunately I get the locale error with Pconf
I tried to use the same settings as you.
My keyboard is german
Do you have an idea?
- 3404gerber
- Thank you received: 14
27 Apr 2025 11:04 #327135
by 3404gerber
Replied by 3404gerber on topic Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!!
I have a LinuxCNC image running on a CM4/eMMC, so it should also work on the Pi5.
- unknown
27 Apr 2025 11:26 #327139
by unknown
If you're going to use a CM5 & carrier board you'd be crazy not to use an NVMe drive. It's fast, like really fast. I use one with mine Rpi5.
- fletch
27 Apr 2025 16:35 #327172
by fletch
I *think* you have to set the localle etc from menu-config - mine was not set for me.Hello
- matn1
06 May 2025 11:33 #327841
by matn1
Replied by matn1 on topic Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!!
Good day,
Adding a voice here as I think I saw another user having this issue: RPI5 with a 7i96, and after some time I get a solid red INIT light on the mesa card, and obviously at that point have to reset the card to continue. I cant make heads or tails of this just yet, but it might be related to idle. It may be specific to the 7i96 given the other poster also commented on that. I have 7i76EU on its way so will be able to test this and post back whether I experience anything similar. Currently the Mesa is on a 5v3A wall plug, and the RPI5 uses a somewhat official USBC RPI wall plug.
Time to create page: 0.212 seconds
