digital outputs remain active after e-stop
- Sandro
- Thank you received: 38
07 Jul 2025 12:39 - 07 Jul 2025 12:42 #331468
by Sandro
digital outputs remain active after e-stop was created by Sandro
Hello everyone,
I've recently noticed that my digital outputs remain active after an emergency stop. For example, the air used for cooling mist or tool cleaning doesn't turn off. Is this normal behavior, meaning I need to handle it in the program myself, or am I missing something? Below is my current e-stop configuration:
Any help would be greatly appreciated!
# E-Stop logic
setp opmode-x-near.in1 8
net x-opmode-display opmode-x-float.in
net opmode-x-float-signal opmode-x-float.out opmode-x-near.in2
setp opmode-y-near.in1 8
net y-opmode-display opmode-y-float.in
net opmode-y-float-signal opmode-y-float.out opmode-y-near.in2
setp opmode-z-near.in1 8
net z-opmode-display opmode-z-float.in
net opmode-z-float-signal opmode-z-float.out opmode-z-near.in2
net estop-button-low lcec.0.CATIO.in-03 => estop-not.in
net estop-tool-sensor-low lcec.0.CATIO.in-00 => estop-sensor-not.in
net estop-button-ext estop-not.out => estop-logic.in-00
net estop-sensor-ext estop-sensor-not.out => estop-logic.in-01
net estop-opmode-x-ext opmode-x-near.out => estop-logic.in-02
net estop-opmode-y-ext opmode-y-near.out => estop-logic.in-03
net estop-opmode-z-ext opmode-z-near.out => estop-logic.in-04
net estop-mpg-low lcec.0.CATIO.in-14 => mpg-estop-not.in
net estop-mpg-ext mpg-estop-not.out => estop-logic.in-05
net estop-ext <= estop-logic.and
net estop-ext => iocontrol.0.emc-enable-in
Last edit: 07 Jul 2025 12:42 by Sandro.
- Thank you received: 1482
07 Jul 2025 13:46 #331475
Replied by Todd Zuercher on topic digital outputs remain active after e-stop
You could possibly use the Halui pin "halui.estop.is-activated" connected to or2 comps to the pins to turn off the mist, flood and what ever other pins you would like changed in the event of an e-stop.
The following user(s) said Thank You: Sandro
- Sandro
07 Jul 2025 13:46 #331476
by Sandro
Replied by Sandro on topic digital outputs remain active after e-stop
Yes, it does, and the amplifiers are disabled as well.
Alright, if that's the expected behavior, I'll program it to disable the outputs myself.
Thank you!
Thank you!
Time to create page: 0.146 seconds
