Adaptive Feed Rate HAL example?
19 Aug 2025 20:25 #333698 by Mars
Adaptive Feed Rate HAL example? was created by Mars
I am only a week or so into LinuxCNC so please bear with me.  My ultimate goal is to use it for a wire EDM machine.  I have been able to get a simple XYZ "machine" running on Raspberry Pi 5 using the GPIO driving some LEDs that simulate step/dir signals to real stepper drivers.  My next goal is to add a signal input that will be used to control adaptive feed rate...ultimately to use it to back up the EDM stages when a short circuit is sensed.  I want to start slow...a single GPIO input bit sends a -1 value when asserted to command the reverse.  Does anyone know of a example HAL file that has includes adaptive feed setup?  TIA.
20 Aug 2025 00:47 #333703 by PCW
Replied by PCW on topic Adaptive Feed Rate HAL example?
If this is just a simple linear back-off it might be something more easily
done using external offsets as is commonly done for Plasma torch height
control.
Otherwise, If you search the forum for motion.adaptive-feed, you will find a number of people
trying the same scheme for EDM
20 Aug 2025 01:57 #333705 by tommylight
Replied by tommylight on topic Adaptive Feed Rate HAL example?
BaxEDM uses LinuxCNC for the EDM machine he builds and sells and as far as i know everything except the power source he makes readily available, although i never checked.
There are many other using it, but usually hard to find, try youtube.
see the description it has a link to a lengthy forum thread.
20 Aug 2025 12:50 #333735 by andypugh
Replied by andypugh on topic Adaptive Feed Rate HAL example?
Starting slow is good, but a single bit input for reverse is probably too slow...
I would suggest setting up an mpg and counter to have variable speed + and -, (like a cheap 16-click rotary switch)
But one way to do what you want would be with a mux block that passes-through +1 by default, and -1 when your bit is set.
linuxcnc.org/docs/stable/html/man/man9/mux2.9.html
loadrt mux2
addf mux2.0 servo-thread
net control-bit mux2.0.sel
setp mux2.0.in0 1.0
setp mux2.0.in1 -1.0
net feed-out mux2.0.out motion.adaptive-feed
See also linuxcnc.org/docs/stable/html/man/man9/m...9.html#MOTION%20PINS
I haven't tested this code, I am at work waiting for something to compile, so don't have access to LinuxCNC to test.
21 Aug 2025 14:18 #333761 by Mars
Replied by Mars on topic Adaptive Feed Rate HAL example?
Thanks for your discussion. A few minutes ago I got my simple concept breadboard running with adaptive feed so that I can throw a physical switch that is attached to a GPIO pin on the Rpi5 and the trajectory backs up. As is typical, once I got some of the basic ideas of the HAL programming (thanks A METRIC TON to swolebro and his excellent tutorials!), I has able to hack a HAL file together. I now need to think more about the system architecture which relates to your discussion. Am I missing something or does the linuxCNC documentation lack one key element that is critical for the newbie: there are precious few if any examples of HAL command syntax in the documentation...not the case for most languages. I think including a few examples per command would greatly lower the learning curve.
28 Aug 2025 13:42 #334039 by andypugh
Time to create page: 0.098 seconds
