Homing is not working
08 Sep 2025 20:16 #334651 by Robert312
Homing is not working was created by Robert312
HAl and ini files attached.  We are retrofitting linux cnc to work with a Bostomatic 3 axis milling machine using a mesaboard.  We have accomplished a lot however we cannot seem to figure out why our machine does not follow the homing procedure.  Jogging works, we have remapped M6 successfully... we even made a bust using the machine.  However when the home all button is pressed (using AXIS as gui), the only movement that occurs is the home offset or home (parameter) however many units they are set. We used halshow to reveal the signals as a way to hopefully diagnose the problem, but we have found is that some signals are not present and they should be.  For example the pins with the verb homing do not get signalled, but those that end in homed are set after the home-all button is pressed.
I have read the Homing Configuration in the docs many times through and we have essentially exhausted every combination of home_search_velocity, home_latch_velocity...etc.  The configuration we want to use is one where latch_velocity has an opposite sign than home_search does and we are using the index, and our soft limits are being shared as the home switch. (home_ignore_limits = YES) .  I've been thinking the only solution is to write a custom homing module using homecomp  or an existing one perhaps cia-402.   A response either suggesting other fixes or how to use homecomp would be extremely helpful.  Thank you
08 Sep 2025 22:46 #334658 by PCW
Replied by PCW on topic Homing is not working
Can you do a:
halcmd show all | grep home > beforehome.txt
With LinuxCNC launched and enabled but before being homed
and
halcmd show all | grep home > afterhome.txt
With LinuxCNC launched and enabled after being homed (well at least home button pressed)
and post both berforehome.txt and afterhome.txt here?
The following user(s) said Thank You: Robert312
09 Sep 2025 13:57 - 09 Sep 2025 14:05 #334700 by Robert312
Replied by Robert312 on topic Homing is not working
I will try both,  thank you! Ill post about the results and those files.
Last edit: 09 Sep 2025 14:05 by Robert312.
09 Sep 2025 14:35 #334703 by Robert312
Thank you for the helpful hal commands.  Here are the contents of the before and after home text files.
09 Sep 2025 15:02 - 09 Sep 2025 15:03 #334709 by andypugh
Replied by andypugh on topic Homing is not working
The docs are quite clear that 1,2,3 is valid for a home sequence. But just as a test, can you try 0,1,2 ?
(Though it's all a bit odd, as the files show that homing has completed)
Last edit: 09 Sep 2025 15:03 by andypugh.
09 Sep 2025 19:11 #334726 by Robert312
The behaviour does not change if I change the home_sequence values to: 0, 1, 2
09 Sep 2025 20:26 #334729 by PCW
Does individual joint homing work?
(comment out the HOME_SEQUENCE settings in the .ini file)
17 Sep 2025 15:10 #335127 by Robert312
Individual homing does not work.
17 Sep 2025 16:21 #335129 by tommylight
Replied by tommylight on topic Homing is not working
Are you still using the above attached config files? They are missing home switch inputs in hal, and Mesa inputs are in the wrong place.
Make a new config, this is to messed up.
17 Sep 2025 17:40 - 17 Sep 2025 18:04 #335133 by PCW
So you are saying that you commented out the HOME_SEQUENCE  lines
in the ini file and then got:
1. Individual axis check boxes for homing in the GUI (Axis)
2. When you selected an axis and pressed the Home Axis
button, the selected axis did not move?
Other questions:
What version of LinuxCNC are you running?
(not that this is likely an issue with an official release since there are probably more than 100000 LinuxCNC installations
using home switches)
So the real question is what is different about your configuration?
Last edit: 17 Sep 2025 18:04 by PCW.
Time to create page: 0.187 seconds
