mux16 is not working for me
- juergen-home
- Thank you received: 15
20 Sep 2025 14:23 #335216
by juergen-home
mux16 is not working for me was created by juergen-home
I'm struggling with mux16, I wanted to implement an decoder for a gamepad.
I although I changed this example code for easy reading and running.
If I use mux8 it is running, if I use mux16 it's not and give me the error: "./mux16.hal:11: parameter or pin 'mux_encoder.in0' not found" . Something there I missed?
mux8
mux16
error log
mux8
# selection of incremental values
loadrt mux8 names=mux_encoder # for incremental steps
addf mux_encoder servo-thread # add these to the servo-thread so it can be used
net demo_input joint.0.homed
# Set the incremental step values for the mux4 component
setp mux_encoder.in0 0 # Increment
setp mux_encoder.in1 1 # Increment
setp mux_encoder.in2 2 # Increment
setp mux_encoder.in3 3 # Increment
setp mux_encoder.in4 4 # Increment
setp mux_encoder.in5 5 # Increment
setp mux_encoder.in6 6 # Jog
setp mux_encoder.in7 7 # Jog
#setp mux_encoder.in8 8 # Jog
#setp mux_encoder.in9 9 # Jog
#setp mux_encoder.in10 10 # Jog
#setp mux_encoder.in11 11 # Jog
#setp mux_encoder.in12 12 # Jog
net mux-set-increment halui.axis.x.increment mux_encoder.out
# connect the buttons with the multiplexer
net demo_input mux_encoder.sel0
net demo_input mux_encoder.sel1
net demo_input mux_encoder.sel2
#net demo_input mux_encoder.sel3
mux16
loadrt mux16 names=mux_encoder # for incremental steps
error log
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.9.4
Machine configuration directory is '/home/cnc/linuxcnc/configs/sim.axis'
Machine configuration file is 'axis_mm.ini'
INIFILE=/home/cnc/linuxcnc/configs/sim.axis/axis_mm.ini
VERSION=1.1
PARAMETER_FILE=sim_mm.var
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=halui
DISPLAY=axis
COORDINATES=X Y Z
KINEMATICS=trivkins
Starting LinuxCNC...
Found file(lib): /usr/share/linuxcnc/hallib/core_sim.hal
Found file(lib): /usr/share/linuxcnc/hallib/sim_spindle_encoder.hal
Found file(lib): /usr/share/linuxcnc/hallib/axis_manualtoolchange.hal
Found file(lib): /usr/share/linuxcnc/hallib/simulated_home.hal
Found file(REL): ./mux16.hal
Debug file information:
Note: Using POSIX realtime
Unexpected realtime delay on task 0 with period 1000000
This Message will only display once per session.
Run the Latency Test and resolve before continuing.
103825
Stopping realtime threads
Unloading hal components
Note: Using POSIX realtimePlease Log in or Create an account to join the conversation.
- Hakan
- Thank you received: 481
20 Sep 2025 14:41 #335217
by Hakan
Replied by Hakan on topic mux16 is not working for me
Try in00, in01 and so on.
The following user(s) said Thank You: juergen-home
- juergen-home
20 Sep 2025 14:58 #335218
by juergen-home
Replied by juergen-home on topic mux16 is not working for me
Thank you for your fast reply Now it's working.
setp mux_encoder.in00 0 # Increment
net mux-set-increment halui.axis.x.increment mux_encoder.out-f <-- and I've forgotten the -f .
- juergen-home
27 Sep 2025 02:59 #335479
by juergen-home
I just found out that I am subscribed to your youtube channel since over 4 years ago. Very interesting videos about your mill and linuxcnc. Thanks a lot.
Time to create page: 0.368 seconds
